15 posts / 0 new
Last post
L00k_C's picture
Mains regulator
Can someone inform me  whether ANY mains regu;ator will do for ANY amp (as long as it covers its wattage needs)?
As i understand it is wiser to use mains regulator from the same brands, if available? If this is not the case will different brand mains regulator make a difference for different brands for amps, cds, streaners etc?
Which mains regulators would you suggest (i will be using it for an Harman Kardon HK990)?
BigH's picture
Last seen: 1 month 1 week ago
RE: Mains regulator
Why do you think you need one?
Listen to the music, not the hifi.
L00k_C's picture
RE: Mains regulator
From what I am reading from forums like these....
BigH's picture
RE: Mains regulator
Really most of the posts I have read have advised against them, here is one: http://www.whathifi.com/forum/hi-fi/audiophile-grade-power-regulator
Maybe you could post some that say you should buy one. Do you mean mains regulator, they are not cheap.j
Bigsounds's picture
Last seen: 3 years 3 months ago
RE: Mains regulator
 Don't think that you need all the things you read, so much of this stuff is a total waste of money, or would possibly make things sound worse. If you really feel you need a mains regenerator, not a filter, then try before you buy.
L00k_C's picture
RE: Mains regulator
an example is CYRUS PSX-R for CYRUS 8a
BigH's picture
RE: Mains regulator
I see, how much is the HK one?
As for the Cyrus PSX-R there seem to be loads at discount prices not sure what that means.
L00k_C's picture
RE: Mains regulator
around 100gbp
BigH's picture
RE: Mains regulator
I would get the amp. first and then see.
abacus's picture
Last seen: 3 hours 6 min ago
RE: Mains regulator
The Cyrus you mention is not a mains regulator, but a separate power supply to supplement the one in the equipment itself, thus theoretically providing a better performance. (They are specific to the manufactures equipment and will not work with others)
A mains regulator is a separate unit that makes sure the voltage remains constant no matter what is going on in the outside world, and will also provide filtering of the incoming power supply, (You will find them in mission critical environments like hospitals, server centres, industrial processes etc.) however in most cases they are way over the top for a home audio system thus any benefit will be minimal.
Hope this helps
Bill
L00k_C's picture
RE: Mains regulator
oH ok... BECAUSE i HAVE ALSO SEEN SOME ADS IN MAGAZINES FOR MAINS REGENERATORS LIKE psaudio ETC AND i WAS WONDERING?
steve_1979's picture
Last seen: 4 days 22 hours ago
RE: Mains regulator
Don't waste money on a generator. Spend it on something worthwhile like better speakers or amplifier.
michael hoy's picture
Last seen: 1 year 1 week ago
RE: Mains regulator
I wouldn't say a mains regenerator is a waste of time, it is though horses for courses and depends what and why you need one.
AV- Panasonic VT30¦Pioneer LX85¦MA Apex Speakers¦Antimode 8033S¦OPPO 95 BDP
Hi-Fi- Spendor A3¦Cyrus 8 XPD QX¦Quad 909 power amp
Music stored on Server running Windows Home Server.
TrevC's picture
Last seen: 1 month 2 weeks ago
RE: Mains regulator
So what problem will a mains regenerator cure?
RobinKidderminster's picture
Last seen: 2 months 3 weeks ago
RE: Mains regulator
My PureAV was a popular choice. Guess its not a regulator?? Hope it doesnt degrade the sq! Good as a distribution box and safety unit
Yamaha V2065. MS Mezzo 5.1 Panasonic 42. Sony BD. Garrard 86SB. WD Live TV. SkyHD.
http://www.whathifi.com/forum/home-cinema/lounge-hc-signature-update-bass-traps
Log in to post comments
