91 posts / 0 new
Last post
Joshuamessenger's picture
Mains cables ?
Do they make your amp sing a little bit better and are they worth the price tag of 40/80 pound
CnoEvil's picture
Last seen: 3 days 7 hours ago
RE: Mains cables ?
Some say YES......and some say NO.
You need to try one for youself from the likes of Clearer Audio, where you get a good trial period....or from your local dealer.
"We should no more let numbers define audio quality than we should let chemical analysis be the arbiter of fine wines."  Nelson Pass
Covenanter's picture
Last seen: 1 week 3 days ago
RE: Mains cables ?
No, but you can convince yourself that they do.  £80 will buy you a couple of bottles of decent wine.  Have the wine and then you current cable will sound wonderful.
Chris
Marantz PM8005 / SA8005 / KEF R700s / AKG K702
MattSPL's picture
Last seen: 1 year 5 months ago
RE: Mains cables ?
I have found they make a difference, but some of the so called Hifi mains cables are just spruced up standard cables with a fancy sheath covering them, and better quality plugs. These are not going to make much difference, yet sometimes cost £100. This is one reason why some people think mains cables are voodoo, because they have never tried a specialist, purpose built cable.
Wireworld and Nordost are 2 manufacturers that spring to mind. They both make specialist Hifi mains cables, and these can make a significant improvement to your system, but they can cost a lot.
I personally rate proper Hifi mains cable above speaker cables and interconnects. I gain greater benefits from Mains cables.
CnoEvil's picture
RE: Mains cables ?
I say Yes; and you will be enjoying the benefits long after the wine is finished.  :shifty:
Macspur's picture
Last seen: 5 days 23 hours ago
RE: Mains cables ?
I'll be trying out an Audience AU24 later this week, at a knock down price, normally  £1200 new!
Have previously tried a Cardas Golden Ref and there were definite improvements...
Incidentally have tried a £5 bottle of wine and a £95 bottle... couldn't tell the difference!
I know what I'd rather spend my money on and I can assure you, only if I can hear a marked difference.
Mac
Electrocompaniet EMC1UP, Audiolab M-DAC+, Sonos Connect, Accuphase E470, Harbeth SHL5 Plus, Auditorium 23 SC, HiFi Racks Podium Reference rack, matching LS stands.
MattSPL's picture
RE: Mains cables ?
Also, if your going to spend money on mains cables, change the fuse in the U.K plug too for an Audio grade fuse like Hifi Tuning. And then change the Ac fuse(if accessable) in the equipment.
abacus's picture
Last seen: 7 hours 20 min ago
RE: Mains cables ?
Make sure you do the test blind, (So that you have no idea which cable is in use) and you will find that there is no difference between cables, so you can stick with what you have.
If you want to hear a difference, make sure you know which cable is in use and your brain will tell you that they sound different, (Even though they don’t) it’s just a normal human failing where other senses override your ears. (Hence the blind test is best as only your ears are in use)
Hope this helps
Bill
jjbomber's picture
Last seen: 4 days 4 hours ago
RE: Mains cables ?
After the wine, shouldn't that be ''do the test blind drunk'' :cheers:
Ben K.'s picture
Last seen: 3 years 4 months ago
RE: Mains cables ?
Try one on 60 day trial from clearer audio. If it sounds better and justifies the price to you buy it. If you hear little or no difference or don't think it warrants the cost return it for a full refund. Simple!
RE: Mains cables ?
I'm willing to bet that none of those who suggest that changing your mains cable will make a difference can put forward any logical explanation as to why that might be the case.  I'd also suggest (ducks) that none of them has any scientific qualification.
Chris
bigboss's picture
Last seen: 5 days 19 hours ago
RE: Mains cables ?
:wall:
davidpr's picture
Last seen: 1 year 6 months ago
RE: Mains cables ?
[quote=MattSPL]
A really good April fools!
RE: Mains cables ?
Might give the 60 day trial ago with the cable, personally I can't see how it would change the out put of the amps signal but for a risk free trail, it's worth the time for the possibility even a slim one for improved sound quality. .
Benedict_Arnold's picture
Last seen: 5 days 7 hours ago
RE: Mains cables ?
Chris
Wine???
80 quid will buy you a couple of bottles of decent malt whisky (or Irish - but God forbid American - whiskey even).  Then your hifi will sound sublime :cheers:
RE: Mains cables ?
BTW IMHO the only things a mains cable needs are 1, to have a 13-amp plug on one end; 2, the right kind of plug on the other end; and 3, to be long enough to make it from the wall socket or surge protector to the hifi.  The key thing to do is to keep your mains cables away from your audio cables so you don't get any mains "hum" being picked up.
Pages
Log in to post comments
