Ls50 to big a sound for a small room?
18 replies [Last post]
Beanz966
Beanz966's picture
Hi  all,
After a lot of reading/research and overall enthusiasm for this audible past-time. Im planning on building my first true performance Hi Fi (Entry level). I have narrowed my focus to the Kef LS50 paired with the Roksan Kandy K2 duo (CD & Amp). However, Im currently in a 3 x 3m room. I had the chance to demo this set up in a store and was amazed by how huge they sounded. I might have listened to them a touch too loud throughout my demo and now looking back im wondering how they would perform in a smaller room that hasn't been designed for acoustic reasons. Any thoughts or experience would be hugely appreciated.
(I know that i have to demo them again sometime)
nopiano
nopiano's picture
RE: Ls50 to big a sound for a small room?
Welcome to the madness, Beanz.
Firstly, you will have played them too loud (we all do!), and secondly, it is very unlikely the room was specially designed.  Most shop listening rooms are far worse than your home!
Any proper dealer will let you try the speakers at home, and do get some good stands.  Your room is cosy but good speakers will still sound ok when played quieter than normal.
You will find several other threads debating which amps suit these super speakers.  Roksan, Naim, Arcam amongst others.
good luck!
__________________
Hi-Fi: Krell KAV-300cd, Michell TecnoDec/RB250/Grado Prestige Black1, KAV-300i amp, Transparent balanced interconnects and bi-wire to Sonus faber Concerto grand piano speakers, Nakamichi ZX-7 cassette deck, Logitech Squeezebox Touch, Hitachi FT-5500 and Sony S570ES tuners, BCD Engineering stand, RA Powerlink, Chord powerchord, Grado SR60i cans.
AV: Sony Bravia KDL-32EX503 telly, BDP-S370 player with QED HDMI. Currently unused: Denon AVR-1705, DVD-1710, KEF KHT1005.2
CnoEvil
CnoEvil's picture
There is a good chance you will be fine, especially if you don't put them in the corner and can leave a little space behind them.
As NP says, try and get them out on home dem.
__________________
"Everything has been said before, but since nobody listens we have to keep going back and beginning all over again."  André Gide
churchill1963
churchill1963's picture
We've had a pair of Rogers speakers for nearly 25 years and really wasn't thinking about buying speakers as they still sound great.  We went to buy a network player and as I was going to pay for it the wife saw the LS50s on the shelf.  The shop set them up so we could have a listen and like you it was loud, the sound filled the shop.  The deal clincher was the sight of the wife crying her eyes out. they sound that good!
Our room is the same size as your and they don't look out of place and they sound truly awesome!
We brought the KEF LS50 a month ago and have no regrets, so try and get a home demo.  I think you will buy them without doubt.
David@FrankHarvey
David@FrankHarvey's picture
My room, while slightly different dimensions to yours Beanz, is basically the same size. I've been using five LS50's for home theatre use, and just two for two channel playback, and they work fine in my room. I recommend using the outer bungs to calm the bass slightly, which gives a more informative presentation.
__________________
David @Frank Harvey Hi-Fi, Coventry
Mitsubishi HC7000 / Oppo BDP103 / Audiolab 8200AP / Rotel RMB1575 / kick ass speaker system
Beanz966
Beanz966's picture
Thanks for all your replys. They are really informative and have settled my mind a lot. I will be sure to keep my mind open about what other options I have in terms of amps and i will see if a home demo is available. Im glad that you all believe they will be fine in this room. I have had my mind set on these speakers for a while. Now its time to start thinking about the other options available. I have been suggested to pair a REL R328 with it to fill out the lower section. This sub might be too big as well though. But the argument about its size is that it should benefit from achieving what is needed effortlessly making it less boomy. However, i was very impressed with what the LS50 managed in terms of bass so not sure if it warrants an extra £1000 to the budget. The Amp and CD player is the following big question. I would quite like to add a turntable to the set as well. However, back to the original topic. You have all been really helpful with answering my initial question. Thanks
David@FrankHarvey
If you're happy with the LS50's bass, then I see no need for a sub. On the other hand, hi-fi speakers, no matter how big, won't reach subsonic bass (not with any meaningful output anyway), so a sub can enhance any speaker.
__________________
plastic penguin
plastic penguin's picture
Online
Beanz966 wrote:
Hi  all,
Just as a reassurance, my room is 13' x 18' and I have the RS6s firing across the narrow side without any bass nasties. As long as you give them about 12" from back wall and away from  the corners they should be fine.
__________________
Leema Pulse MKII-S; Naim CD5i MKII; Denon TU-260L MKII; MA RS6 speakers; Pro-ject Xpression 1; loads of different cables...
Formerly known as plastic penguin
antskip
antskip's picture
The KEF LS50 manual positioning guidline is for back of speakers to be a minimum of 20" from back wall and 40" from sidewalls; or with outer ring of rubber filler: 8-20" from back, 20-40" from sideall; closer positioning requires both rings.
__________________
Rega Brio-R integrated amp, Rega Apollo-R cd player, Tellurium Q Green speaker cables, Tellurium Q Black interconnects, Rega Isis/Osiris mains power cables, KEF LS50 speakers.
nopiano
nopiano's picture
Oops.  That means in the OP's 3 metre room they will be just a metre apart if placed a metre from each side wall.  [Having checked that 40 inches is near enough a metre!]   With outer ring they'd be OK though, in theory anyway.
__________________
antskip
antskip's picture
Good point! A seriously small room! Yes, both rings would need to be in place to effectively close the back outlet so the speaker can be placed next to a wall. But I would wonder about the rightness of the LS50 for such a room. But who knows till you try?! (smile)
__________________
churchill1963
Yes both rings have to be used as recommend by KEF.  You can have them close to the walls. Ours are approx 18 inches from the side walls and 7 feet apart. 8 inches from the rear wall.  It works for us with the system we have and as you say no harm in trying!
alchemist 1
alchemist 1's picture
    3m x 4m room.  LS50'S  200mm from rear wall, no bungs,no boom,
    Just solid bass and large sounstage.   Smile
David@FrankHarvey
Mine are 6-7" from the rear wall with the outer bungs. The guide is just that - a guide, not gospel.
__________________
Beanz966
Beanz966's picture
Wow, its turned out to be a pretty good debate. I think with Careful repositioning of my furniture. I should be able to create enough room to give them space to breath. I had not heard of the bungs until now so i guess thats also always an option if its still not sounding right. The space for a sub and whether its needed in this room is another question. It might be a bit wild. Although, on that note, it does make me crack a smile at the thought of it. From what i gather though, the use of stands and turning them in a little should give them enough room. Yes it will be cosy, but as a couple of you said, 'its worth a try'. Thanks again for all the feedback
plastic penguin
Online
As David said, they are guidelines and not to be taken literally. Totem suggest around 6" from back wall for the Arros, and they stand 85cms tall.
http://totemacoustic.com/en/hi-fi/columns/arro/specifications/
__________________
