Looking for a kitchen system - options and advice needed
39 replies [Last post]
AlmaataKZ
AlmaataKZ's picture
I want to update my ancient music system in the kitchen.
The objective is to improve sound quality while maintaining (or improving) the ease of use.
Must haves: The system must be able to play all music from a macmini itunes library (which includes DRMed and not DRMedAACs, mp3s,mostly ALAC up to 24/96 (down sampled playback or skipping a track is OK but just stopping is not). The user should be able to easily select any music (by artist, album or playlist) and play it with minimum number of steps – not exceeding the current. Particular focus is on this aspect – the new system must not complicate the process and preferably simplify it. If the system powers down automatically it should wake up by itself if music is sent to it. If it does not power down it must have very low power consumption when not playing.
Nice to haves: Preference for active speakers. White/silver sleek modern styling. Least number of boxes and cables, including power supplies.
Budget: Unlimited, but the less the better, other things being equal.
Currently, the music is played locally from an 3rd Gen ipod (which has all music library copied to it) via a small speaker dock. The current operation is: the dock is permanently plugged in, the ipod is permanently in the dock. 1. Switch dock on, 2. Wake ipod by a touch, 3 select music (maybe several steps here). 4 press play. To sitch off: 1. Press stop 2. Switch dock off.
Ideally, I want a system with two speakers, with own amplification and own touch screen which can pull music from the library wirelessly and play all of the files (i.e. no need to bring in and use additional hardware e.g. iphone to control it and/or send music to it).
What currently available systems will allow the above?
bigboss
bigboss's picture
RE: Looking for a kitchen system - options and advice needed
__________________
bigboss
bigboss's picture
AlmaataKZ wrote:
Ideally, I want a system with two speakers, with own amplification and own touch screen which can pull music from the library wirelessly and play all of the files (i.e. no need to bring in and use additional hardware e.g. iphone to control it and/or send music to it). What currently available systems will allow the above?
This is a difficult one.
This system will satisfy most of your requirements, except for the fact that you need a controller:
http://www.teufelaudio.co.uk/raumfeld-audio-streaming/raumfeld-speaker-s-(sog)-p6709.html
__________________
BronC
BronC's picture
What about connecting your ipod to a denon DM39 with a decent set of small speakers?  That way you get a decent radio as well.
__________________
CnoEvil
CnoEvil's picture
It's probably totally wrong for you, but just in case it isn't:
http://www.whathifi.com/review/linn-kiko
__________________
"Everything has been said before, but since nobody listens we have to keep going back and beginning all over again."  André Gide
chebby
chebby's picture
Surely the obvious choice for you is ADM9s (I think gloss white is an option). Just plug in the Mac Mini to it's onboard DAC.
There are the Dynaudio Xeo 3s but they have a seperate DAC/transmitter that needs it's own mains connector. (Gloss white though.)
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Apple iPad Mini • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
AlmaataKZ
AlmaataKZ's picture
just looking at these. They all need an additional base and a controller - eitherva dedicated one or an idevice. Additionally, with the separate speakers options, which I would prefet and put high on cupboards, the volume control knob cannot be reached.
otherwise quite good products.
AlmaataKZ
AlmaataKZ's picture
I actually have a dm38. Just tried but it does not power or playback from the old ipod via usb. The ipod is too old.
AlmaataKZ
AlmaataKZ's picture
CnoEvil wrote:
It's probably totally wrong for you, but just in case it isn't: http://www.whathifi.com/review/linn-kiko
I think it is a good system. Especially neat is that speakers are active but do not need power cables. But its tiny screen is hopeless so it needs an additional controller. Also it has loads of stuff that I do not need.
AlmaataKZ
AlmaataKZ's picture
macmini is in a different room, so I would need an airport express to feed them + a controller. Still, this is an option.
xeo 3 needs a usb sender to which I think I will have to manually switch macminis output every time I want music in the kitchen. And then back. Not suitable. EDIT unless i connect the transmitter to minijack while normal macmini output to usb. I hope the analog out of macmini always outputs the same signal as goes to usb??
another workaround for xeo would be feed the transmitter from an airport express and use airplay. But it is clumsy.
moon
moon's picture
Maybe use a ipad mini as source, using Home Sharing so you  can stream all your tunes from the mac mini. You can then use all the other apps it has as well, like Tune in and iplayer etc . It has a nice display and perfect for the kitchen. It can also be wall mounted.
Take a mini jack lead straight into  something simple with one input like a hidden mini T amp which use EDITED all power. Then connect to some speakers of your choise for the kitchen.
My kitchen system is Ipad> T amp> KEF 2001.5.        simples
All my speaker cables are hidden in the walls
__________________
AlmaataKZ
AlmaataKZ's picture
yes, this is a very good and straightforward option. But I want to avoid having to bring idevices into the kitchen to be able to play music there. The kitchen system should work on its own.
moon
moon's picture
these might or might not be rubbish but do have lots of inputs and come in different colours
http://www.rothaudio.co.uk/docs/products_09/OLi_POWA-5.shtml
__________________
BenLaw
BenLaw's picture
Online
It seems to me your major limiting factor is the desire for a touchscreen on the unit, and consequently not controlling it by a remote such as an idevice. So SBT plus actives of choice?
__________________
HiFi   /   A/V   /   Bedroom
moon
moon's picture
yeah I see, but I am suggesting having the ipad permanently in the kitchen, wall mounted and all futuristic like. Smile.  like mine is
will try and post a photo
__________________
AlmaataKZ
AlmaataKZ's picture
wow. I am not sure I can afford that! :-)
