9 posts / 0 new
Last post
MJ23's picture
Last seen: 3 years 7 months ago
KIMBER CABLE USB B BUS-ag
hello everyone, somebody know this cable?
kimber cable usb b bus ag?
thanks Smile
TrevC's picture
Last seen: 2 months 3 weeks ago
RE: KIMBER CABLE USB B BUS-ag
http://lmgtfy.com/?q=kimber+cable+usb+b+bus+ag%3F
MJ23's picture
MJ23's picture
another question what do u think about
Chord USB SilverPlus digital?
CnoEvil's picture
Last seen: 2 weeks 6 days ago
If you think a USB cable can make a difference, this one would be my choice: http://www.whathifi.com/review/vertere-pulse-d-fi
Try to do a home trial before purchase.
"We should no more let numbers define audio quality than we should let chemical analysis be the arbiter of fine wines."  Nelson Pass
MJ23's picture
ok but what about the Chord SilverPlus is good?
stephennic's picture
Last seen: 2 years 2 months ago
Another Mag (HFN) did a review recently comparing 10 USB, both of these did very well.
Steve.
MJ23's picture
ok thank you!
Crossie's picture
Last seen: 3 months 2 weeks ago
Do buy a cheap one first for a couple of quid and see what its like. You then have something for comparison. IMHO its a digtal lead and won't make any difference, you may of course make up your own mind. I would be tempted to put the money towards buying some high def music down loads.
Just because you are paranoid does not mean that they are not out to get you.
Log in to post comments
