72 posts / 0 new
Last post
estidog's picture
Last seen: 3 years 1 month ago
incorrectly matched Ohms?
Smile Ok I'm a total newbie round here, and a total newbie to hi-fi specifics in general.
I've had a set up for my vinyl player for 4 years now and am starting to get itchy to upgrade something - please feel free to comment on my system - I have no idea if one bit of kit is much better or worse than the rest. My hunch is i need a better amp? especially as I've started reading about matching ohm levels and i don't think mine are matched?)
Turntable: Technics SL-DD33 (seems good enough to me...) paid £35 second hand
Amp: Technics SU-X102  (8Ω to 16Ω) paid £20 second hand
speakers: Eltax Concept 400s (4Ω-8Ω) paid £180 i think new.
Am I right in thinking my amp isn't handling my speakers very well?
If anyone looks at this and thinks one bit of kit is not up to par with the rest then please say!
thanks!
estidog's picture
RE: incorrectly matched Ohms?
Am I posting in the wrong forum or something? I know I'm new here but kinda wondering why my posts aren't attracting any comments? Are these dull questions?
Al ears's picture
Last seen: 2 days 13 hours ago
That's because we are all in bed by 20:00hrs Smile
At your sort of budget I would not worry yourself about ohm matching, leave that to those with lo-power valve amp setups.
If you are happy with your room / speaker setup then go and get a better amp. Just make sure it has a phono stage built in. You might also consider upgrading the cartridge fitted to your turntable.
Motto: Never pay full price for anything, there is always room to haggle!
Tom Evans Audio Design amplification / Acoustic Zen Adagio speakers / Dr. Feickert Analogue Woodpecker-SME310 / Oppo 105eu
namefail's picture
Last seen: 4 months 3 weeks ago
As long as you are using the correct speaker outs on you amp (Main) as list in the manual I can't see you having an ohm issue. Whats making you itchy?
P00dl3's picture
http://en.wikipedia.org/wiki/Impedance_matching describes the theory, sure it may not be operating in its sweet spot but all you will be losing/wasting is a little power.
BigH's picture
Last seen: 1 month 1 week ago
To be honest I think you need to change all of it. First probably the amp. but what budget do you have?
Listen to the music, not the hifi.
Al ears's picture
Ouch. I was trying to be kind, but agree. :grin:
estidog's picture
Thanks folks for the comments - good to get a discussion going!
I'm feeling itchy because I had borrowed someone's good speaker cables (£6 a metre on Richer Sounds) and realised how much better it gives for the bass response, and so have started questioning my setup.
I'm thinking of getting a technics SU-V460 because of footprint size and power and it would match the Ohms of my speakers (around £130 buy it now on ebay - is this a good price?) , but am not really sure if it is proportionally much better than the amp i already have? Also because of room issues I would like to get a new amp that would be the same footprint size as the vinyl player so they can stack (although i've recently read this is bad?).
In terms of the cartridge - upgrading this sounds like it wouldn't be too expensive - could you recommend one? - Currently it has the original technics one on there and even though i bought a replacement unbranded p-mount stylus a few years ago, the original Technics stylus until recently sounded much better than the new one, even though it must have been 5+years old (and I play records a lot!).
So would people agree that investing in better speaker cables, a new amp, and new cartridge would be money spent in the right places?
p.s. often I feel like the rare times when I do crank the volume a little bit - it doesn't sound very clear with slight distrotion, but It's hard to tell if I'm imagining this!
estidog's picture
I agree, i'm looking to invest in a good setup for the long term so happy to do this in stages and keep this as a project when I have the money to replace bits. Right now I could spend maybe £100-£150 on something. I'm into buying second hand btw - I'm only using the setup for vinyl - so I'm not too concerned with buying new.
Vladimir's picture
Last seen: 10 months 1 week ago
Forget everything else for the time being. Focus all your financial efforts on getting good speakers.
Al ears's picture
Probably not the way to go with this system.
Get the source then amp sorted first otherwise how are you going to know whether speakers are 'good' or not.
Vladimir's picture
Get the source then amp sorted first otherwise how are you going to know whether speakers are the ones for you or not.
:shame:
The Hi-Fi golden rule is you get the speakers first then get everything else to get them sound the best they can. The speakers are the biggest leap in sound quality forward than any other component you upgrade. They define most of the sound performance you get from your system.
RobinKidderminster's picture
Last seen: 2 months 3 weeks ago
This is not another cable debate but all would (hopefully) agree that with an entry level system (as we all start with and many stick with) a cable change should make no difference. Try some basic cable first, it can always be used later, your old cable may have had a severe weakness or serious oxidation maybe. Others will recommend amps etc.
Is the cartridge decent? Alignment & weight/bias is crucial for vinyl at any budget before changing anything. If the vinyl source is poor then no money will improve elsewhere (imo).
Yamaha V2065. MS Mezzo 5.1 Panasonic 42. Sony BD. Garrard 86SB. WD Live TV. SkyHD.
http://www.whathifi.com/forum/home-cinema/lounge-hc-signature-update-bass-traps
estidog's picture
The cartridge is a Technics P30 with a Technics P30s stylus on top. Can someone recommend a better cartridge to get if it would help the source sound better? I now have an unbranded stylus though as a replacement. Is the cartidge more important than the stylus?
my speaker cables were £4 a metre (4 years old - fine condition) but I really can tell the difference between these and the pair I borrowed off my friend, mainly just in that there's audibly more bass with his cables. I borowed his phono cables too going from vinyl to amp, which were twice the price of mine (£80 - mine were £40), but I couldn't tell that much difference, not as much as the speaker cable change anyway.
I need to buy an amp anyway for use in an art exhibition where the sound quality isn't important. So i figured I might as well use my current one foir that and buy a better one for home, rather than have two cheap amps at the end of the day.
Does anyone have any thoughts on the Technics SU-V460 or perhaps a Nad 302?
BigH's picture
I don't know the SU-V460 but it looks better on paper than your current one. Anyone know if its better than a Pioneer A400, they were very well rated a few years ago.
As for your turntable do NOT stack it on top of your amp that will not be a good idea, best to buy a wall shelf for it if you can.
estidog's picture
Is it possible to stack a vinyl player on an amp if there are some sort of spacers in between to let heat dissipate?
Pages
Log in to post comments
