If you were starting from scratch with £2k.........?
62 replies [Last post]
SteveD
SteveD's picture
Starting from scratch and auditioning session set up for tomorrow, current thinking which I would be grateful for views on please:
OPTION 1
Rega Brio-R
Rega DAC
(possibly Rega Apollo-R CDP but most music on laptop so DAC most important)
Rega RS3
OPTION 2
Audiolab 8200CD
Audiolab 8200A
Rega RS3
Have heard Audiolab amp is a little too analytical and lacking natural warmth - is this your experience too?
Should I consider Naim Nait5i Amp with 8200CD?
Rega Brio-R amp with 8200CD?
OPTION 3
Naim Nait5i amp
Naim CD5i cdp
Rega RS3
Not sure what DAC would work with this??
Also for me this is a pushing the budget out expensive option and not sure the sound will be worth the extra cost.
Would also be particulary grateful for views on speakers for these options, based on research and comments am thinking RS3s as had floorstanders before (old ones!) and the RS3s can be situated close to a wall with great reviews.
__________________
MacBook Air > Chord Company USB Silver Plus > MF V-Link II > Chord Optichord > Rega DAC > Tellerium Black I/C > Rega Brio-R > Tellerium Black S/C > Rega RS3s
iTouch > Graham Slee Novo > Grado SR80is
audioaddict
audioaddict's picture
RE: If you were starting from scratch with £2k.........?
Hi mate i heard the marantz cr 603 with dali zensor 5 and it was stunning and wld save you a fortune it really would surprise you
__________________
Audiolab 8000cd 8000q 8000 monoblocs x2 arcam t32 tuner technics sl1200 mkll b&w cm1atacama nexus 6 stands qed silver anniversary speaker cable audioquest interconnects
igglebert
igglebert's picture
For me, my signature.  And I've spent a lot more before.
gregvet
gregvet's picture
Personally I am always looking for good deals, so at the moment I would be looking at a Cyrus 8xpd qx (£1199 from several online retailers currently). Would go nicely with your laptop as a source, and leave £800 for speakers. Bound to be some nice options at that price point, especially if you look at ex dem and second hand options. Personally I love Spendor and Pmc speakers with Cyrus, but loads more to consider.
the record spot
the record spot's picture
I wouldn't want to have multiple components, I'd look for a centralised solution that works right out of the box; not necessarily the Onkyo I have, that's but one example of the same.  But easy accessibility, convenience and sound quality are a must.
__________________
Onkyo TX-8050 / Tannoy Revolution DC4 / Denon DVD-3930
Sony PS3 320Gb
SteveD
SteveD's picture
Thanks all
Audioaddict, will have a listen then, they're selling the Marantz MCR603 for £379 in the store I'm going to so even better price but they don't stock Dali's unfortunately so will have to be a different pairing.
Igglebert, thanks, have been reading up on the AVIs and agree should be on the list for a listen.
Gregvet, cheers, need to look the Cyrus up, not familiar although probably should be!
The RS, I should have said I've certainly not discounted the Onkyo TX 8050 either (how could I having read your thread!) but unfortunately although the dealer I'm going to see tomorrow stocks Onkyo they don't have it in so will have to try that elsewhere.  By the way I hope, if you read my 1 month journey back into Hi-Fi thread, you saw the funny side of my comments which are totally tongue in cheek.
The traditionalist in me says to go for separates (I had a separates set up last time) but it's very interesting to see all the responses are variations on a theme of "less is more" when it comes to boxes.
__________________
altruistic.lemon
altruistic.lemon's picture
Option 1 with better speakers.
SteveD
SteveD's picture
Thanks, what would you recommend for the speakers, up to £1k max and need to be able to position close to a rear wall but with space at the sides?
__________________
chebby
chebby's picture
Option 1 with the same speakers. Look at P46 of the January 2012 issue (same brand systems group test) for why.
The very same system you listed (in option 1) was the group test winner (even against a Naim/Neat system costing almost £3000 more).
The Rega RS3s were rated highly with 5 stars - in the same test - so don't be discouraged from giving them a demo.
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 4 32GB • iMac • Panasonic TX-L32D25B • Sony BDP-S390 • Vita Audio R1 MkII • Humax HDR-Fox T2
SteveD
SteveD's picture
Appreciate your comments Chebby, it's looking like the number 1 option still.  Didn't know about that review so will try to look it up - your review of the RS3s and comments on your own speakers were a big influence in my thinking to shortlist them along with comments from JonathanRebecca.
Surprised that people don't seem to rate the Audiolabs though, especially given the review the 8200CD got in the 2011 awards?
__________________
SteveR750
SteveR750's picture
None of them. But if I had to choose then #3
__________________
Sony Viao / J River MC17  -> CA DACMagic Plus -> Caspian M2 -> ProAc D18
SteveD
SteveD's picture
Hi SteveR, not meant to be limited to those, looking for views on what else to consider and very interested in yours?
__________________
matthewpiano
matthewpiano's picture
I'd probably go for a Marantz CD6004 with the Onkyo TX8050, and a pair of Quad 12L Classics and spend the rest on music.
__________________
Squeezebox Touch (for FLAC rips of CDs, internet radio, and Napster) > NAD C326BEE > Dali Zensor 1
SteveR750
SteveR750's picture
When I had that budget to spend 2 years ago, being impatient, and only visiting on dealer in cardiff, I was limited to Naim, Arcam, Cyrus and Roksan. I listened to a one make version of all, except roksan as there was no K2 CDP in stock, so we used the cyrus CD6se as a control reference.
I thought the combination of the forwadness and bounce of the cyrus matched the slightly more conservatibe K2 well, and was to my ears the best of all of the combinations, though the Naim system was very close, and were it no so idiosyncratic in its looks and operation I might well have gone for it. I think ulitmately that  most half decent bits of kit will work brilliantly when partnered with something "right" which is why the star ratings should only be used as a rough guide; frenkly choose something if you really like it / look of it, as with the right partners it will shine.
The CDP has since gone in favour of a laptop as it was better again, though suspect a linn sneaky might appear some time in the future.
Have you thought of used gear?
£2k will get you some very nice slightly used gear indeed, possibly from a level higher than you are looking.
__________________
SteveD
SteveD's picture
Hmmm.  "Patience is studied as a decision-making problem, involving the choice of either a small reward in the short term, or a more valuable reward in the long term. When given a choice, all animals, humans included, are inclined to favour short term rewards over long term rewards. This is despite the often greater benefits associated with long term rewards."
I suspect like all the animals(?!) I may succumb sooner rather than later but really appreciate what I know is very good advice.
__________________
the record spot
Absolutely fine Steve; I hope you're happy with whatever you end up going with.  It's what's right for you in the end that really counts.
__________________
Sony PS3 320Gb
