Ideas on a phono cartridge
Hi Guys
I'm looking at getting a new turntable, the deck is a new one from SRM/Tech running a RB250 arm with Incognito rewire. I could do with some advice on a suitable cartridge. Have heard a deck with an Ortofon MC1 turbo, sounded great but was on a Project deck. Ortofon make so many models, I'm lost! Ideas?? I live in Berlin, and ortofon is widely available here, other names I'm not so sure of....
What's your price range? (Goldring's new range is sounding rather good, BTW)
Hi and that's for the commentsDenon and Goldring I can add to my hit list.My budget is say £150. I have a Naim pre/pwr/cd combo. Got that 'cause I loved the clear detailed sound. I'm looking for the same from my turntable. I prefer LPs over CDs for a lot of my music, more dynamic.Oh, I run a project tube boc via clearaudio cables if that helps.Really appreciate your help!
I'm using a Goldring 1042 MM cartridge on a Rega300 with Incognito re-wire and it sound excellent. Goldring have just brought out new models (the reviews don't suggest thay are much better) so you might pick up a 1042 cheap.
Jim
Thanks Jim, The goldring is still selling for approx 250euro here so will keep looking out for a cheaper one. Question, why did you opt for an MM over an MC?
I read lots of reviews, technical articles etc and they all pointed to the fact that a good MM would beat
a high output MC into an MM phonostage which was all I had at the time. I admit I've now picked up
an MC headamp and thinking about MC. Again, the low cost MCs don't get great reviews so I'm looking
at the Ortofon Rondo Bronze at £500 - which looks like the sort of price where the MM/MC diference
really kicks in.
ps I strongly recommend the Michell TechnoWeight upgrade to the Rega arm, it made an instant and
very obvious difference.
It's all a matter of taste but I love the Denon cartridges...
DL-103 or DL-160... Smooth sound.
