i tunes problem
Sun, Jun 24 2012, 8:02PM
Hi all My Sons Girlfriends is having a problem with i tunes I am sure that you guys will know the answer when trying to import a cd to her itunes on her laptop the cd track listing comes up and the albumb starts to be imported the 1st second of track 1 and thats your lot any help would be very welcome
Mon, Jun 25 2012, 8:13AM
#2
Hey toyota man, open itunes---preferences---you will find the following option:
When you insert a cd----change the corresponding option to--ask to import
This will fix your problem
Mon, Jun 25 2012, 6:47PM
#3
Hi Shafesk many thanks for your reply I will pass on your advice
- Login to post comments
just in case some body has missed this post
Musical fidelity M6i Roksan caspian M2 cdp Atc scm 40s Tellurium Q black speaker cable chord chamelian xlr graham slee novo sennheiser hd598
