I fancy a spot of bi-amping
Thu, Mar 21 2013, 8:41PM
Could I use an Audiolab 8000P power amp to do this with my Onkyo 8050?
Thu, Mar 21 2013, 10:27PM
#2
Technically yes but unless the onkyo and audio lab have the same gain you will have disparate levels. Personally I wouldn't bother.
Fri, Mar 22 2013, 9:23AM
#3
Yes I agree. I think you'd also have to have equal runs of the same cable. Even then you might end up with slight timing differences (at least that was my experience when I tried biamping using different brands with different power ratings).
Fri, Mar 22 2013, 2:29PM
#4
Thanks. I'm still learning. So in reality my only option would be to bi-amp with another Onkyo 8050?
- Login to post comments
Musical fidelity M6i Roksan caspian M2 cdp Atc scm 40s Tellurium Q black speaker cable chord chamelian xlr graham slee novo sennheiser hd598
