I do like my Cyrus but......
19 replies [Last post]
char_lotte
char_lotte's picture
Evenin' all....
I've posted mainly in the music section and in the comedy sectionnow and then , but alas the time has comefor a serious question.....
I have a pair of cyrus mono blocks and Spendor speakers and am using an older Cyrus integrated amp as a pre.
I would quite like a "proper" pre amp any suggestions valves or ss considered.
Thanks Charlotte
plastic penguin
plastic penguin's picture
RE: I do like my Cyrus but......
Hi char_lotte
What is it about the sound you don't like? Do you have a budget in mind?
There are many options, so bit more detail would be good.
A few suggestions to start the ball rolling:
Quad; Newer Cyrus; Naim; Roksan...
__________________
Leema Pulse MKII-S; Naim CD5i MKII; Denon TU-260L MKII; MA RS6 speakers; Pro-ject Xpression 1; loads of different cables...
Formerly known as plastic penguin
SteveR750
SteveR750's picture
Which Spendors?
__________________
JRiver MC17 -> Cambridge Audio DACmagic+ -> Roksan Caspian M2 -> ProAc D18
Alears
Alears's picture
Unless there is something you do not like about the sound then the obvious answer is sell integrated and buy newer Cyrus preamp as has been suggested.
If you are attempting to change the sound then that is a whole new ballgame ............ just wait for the weird and wonderful suggestions to come rolling in............ then just go and audition whatever you can.
__________________
Origin Live Aurora Gold+Illustrious Mk2 arm+Zyx R100-02/Stello CDT200+Stello DA220 Dac/Tom Evans Groove Anniversary/Tom Evans Vibe Preamp/Linear A power amp/Acoustic Zen Adagios/ Chord cables
bluedroog
bluedroog's picture
I'm very happy with my valve Croft micro 25 pre into ss power. Don't expect features but the sound at the price is second to none. It will give the Cyrus a much bigger sound.
char_lotte
Morning, apologies for lack of detail in my opening post. The potential change is
due to the fact that the last month or two most of my listening has been through
headphones and a little Ant Amber headphone amplifier.
I've been surprised just how much I enjoyed it, however , longterm headphone listening isn't
for me and I guess I may just be attempting to recreate that type of "lush" sound.
I have original mono x's through Spendor s9 speakers with cd7q cd player. I love the detail that I can get with the monos , just wondered if a little change could add a little extra....
CnoEvil
CnoEvil's picture
You don't mention budget, but as well as Croft, I would throw out these:
Ayre K-5xe MP
McIntosh C220
Mastersound PHL5
Sugden LA-4
Pure Sound L10
Raysonic C200
Icon Audio LA4 Mk11
Quad QC 24
Unison Research C5P or Unico Pre
__________________
"Everything has been said before, but since nobody listens we have to keep going back and beginning all over again."  André Gide
gregvet
gregvet's picture
Online
Do you have a budget in mind, and are you willing to take a punt on something second hand?
I have heard that you can fairly easily improve on the pre section of a Cyrus integrated so it shouldn't be too hard to get some improvements. Cyrus and spendor do go well tho, so I wouldn't be changing anything else just yet  Smile
__________________
Bedroom: Sonos ZP90, Cyrus DAC XP+, Cyrus X Power, KEF LS50's
Living Room: Linn Majik DS, Marantz UD7006, Arcam AV9/P7, PMC FB1i fronts, TB2i centre, DB1i rears
David@FrankHarvey
David@FrankHarvey's picture
If you want to stick with Cyrus, the obvious choice would be the DACxp+. It is an excellent pre-amp that we've used with four Mono X300's though KEF Blades without it showing any shortcomings.
And yes - we have clients using that combination Smile
__________________
David @Frank Harvey Hi-Fi, Coventry
Mitsubishi HC7000 / Oppo BDP103 / Audiolab 8200AP / Rotel RMB1575 / kick ass speaker system
char_lotte
Hi all thanks for suggestions, not hung up on price and second hand is fine.
I'm not a box swapper and not planning on changing anything else just curious as to what else
I can gain going for a dedicated pre. I quite like what I've read about Sugden....so that could be an
interesting suggestion. Thanks for that.
gregvet
gregvet's picture
Online
I'm not sure I can add much to the suggestions above. To achieve the sound you are describing, I would think a class A or valve pre would be your best bet and I've no experience of either.
I have the 8xpd qx with spendor sa1's and I love the combo. I have just bought an x power tho and am planning on swapping the integrated for a pre, so let me know how you get on! I need a dac too tho and am planning on the dac xp+ unless I get convinced otherwise.
Fennermachine on here used a quad pre with Cyrus monos for ages and was happy with the two together. Just to give another option. He might even pop in and offer an opinion if you are very lucky  Wink
__________________
the record spot
the record spot's picture
How about a passive pre-amp by the likes of Icon Audio (around £400) or Tisbury Audio (from £135 or so)?  Both can be found on Ebay.  All you get is a selector and volume and that's it.  Some of these can be ordered to spec, depending on the number of inputs you have.  Worth reading into if nothing else.
__________________
Onkyo TX-8050 / Tannoy Revolution DC4 / Marantz SA7001-KI / Apple TV 3 / Sony PS3 320Gb / Denon DVD-3930
char_lotte
Many thanks for all suggestions, will look out for them. Also thanks Record Spo
t will check those too.
FennerMachine
FennerMachine's picture
Online
Hi char_lotte
I had a similar system to yours, CD7Q + PSX-R, aCA7.5 Pre, 2 x Smart Power in mono mode.
I now have the system in my signature.
I used the Cyrus combination with Mission 782, Von Schweikert VR1 and Spendor SA1 speakers.
Like you I found the detail can be great but I personally found that this combination can lack warmth or feeling. It was also fatiguing on long listening sessions.
I changed my pre amp to a Quad 44, a vintage pre amp over 20 years old.
The one I have needs special interconnects but they are not expensive. The bonus of this is that I've decided to stick to the Quad cables so no longer need to worry about cables!
It kept most of the important detail of the aCA7.5 without being harsh sounding but also gets even more out of music possibly due to being very good in the mid range. Its not boomy and is never harsh.
I had mine for a few months before something blew on it, the service was reasonable and guaranteed for a year.
Worth considering as they are not too expensive.
Worth doing research first though as there were several revisions.
__________________
CA 751BD , QUAD 44 pre amp, Quad 303, Quad 21L2
Denon AVR-3801, Samsung LE32R87BD 32" TV, Quad L2 Centre, 78DS
char_lotte
Thanks Fennermachine....I like the idea of old-skool.....many thanks.
MUSICRAFT
MUSICRAFT's picture
char_lotte wrote:
I would quite like a "proper" pre amp any suggestions valves or ss considered. Thanks Charlotte
Hi char_lotte
I'll recommend looking at alternative makes of pre amplification as i don't feel that Cyrus pre amplifiers are on par with the performance levels offered by their own source components and power amplifiers.
Resonessence Labs Invicta DAC/pre amplification and Antelope Audio' Zodiac Gold 384kHz DAC/pre amplication are also worth a look. If you use your Cyrus CD7 as a transport only then you're also likely to gain even greater quality of performance from your CD's by using the Invicta's and the Zodic's digital to analogue conversion technology.
http://resonessencelabs.com/
http://www.antelopeaudio.com/en/products/Zodiac-Gold-DAC
Btw, i just want to be clear that i don't benefit by recommending the Invicta and Zodiac Gold 384kHz as i don't deal with Resonessence Labs and Antelope Audio.
All the best
Rick @ Musicraft
__________________
Musicraft (Derby), Specialist Hi-Fi/AV & Multimedia Dealer
good accurate audio monitoring and good sound reproduction to all Smile
