How to make a SS amp sound like a Class A?
94 replies [Last post]
plastic penguin
plastic penguin's picture
Nope, not getting rid of my Leema, interested in seeing how close one could get without the amp losing its essential qualities... what speakers and source.
__________________
Leema Pulse MKII-S; Naim CD5i MKII; Denon TU-260L MKII; MA RS6 speakers; Pro-ject Xpression 1; loads of different cables...
Formerly known as plastic penguin
Overdose
Overdose's picture
RE: How to make a SS amp sound like a Class A?
Some solid state amps are class A, or have I missed the point?puzzled
__________________
Mac mini > AVI ADM9Ts
plastic penguin
Yes, I was trying to be a little subtle. Clearly it didn't work on this occasion.
__________________
Overdose
Overdose's picture
Do they sound different? Class A, from other types that is?
__________________
chebby
chebby's picture
The Pulse is a class A/B amp, but the point at which it goes to class B is virtually at 'switch on' (or about 0.5 watts).
Some A/B amps 'switch over' to class B at a much higher output (ATC amps remain in class A operation until about 2/3rds of their maximum output for instance).
So, practically speaking, the Pulse is never going to operate in class A even at very low outputs.
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
Electro
Electro's picture
I don't think you can make any amp sound like class A if  it is not class A puzzled
The main difference in the class A sound comes from the complete elimination of crossover distortion which is a type of distortion that can make an amplifier sound grainy and harsh .
Class A operation completely eliminates this type of distortion but at the cost  of low efficiency and considerable heat output combined with large size and weight .
Just because an amplifier is a class A design it does not automatically mean it will sound better than any other type of amp ie AB / B OR D , in my opinion the quality of design and the parts used are equally important to good sound quality but CNO may not agree with my last statement  excellent!    Wink .
__________________
Electrocompaniet EMC1UP Cd player , EC 4.7 pre , AW120 DMB power amp , PMC PB1i speakers . Isotek Titan / Nova , Nordost SPM speaker cable , Kimber KCAG balanced interconnects .
Linn LP12 Lingo , Ittok lv3 , Lyra Lydian , EAR834P .
"Everything should be as simple as possible, but no simpler."     Albert Einstein .
Overdose
Overdose's picture
Crossover distortion? So whatever this is, Class A amps eliminate it?
Edit: I see, yes. Not the speaker type crossover then.
__________________
plastic penguin
So my Pulse, let's say, with Harbeth speakers wouldn't sound anything other than analytical? With certain music it does sound quite organic or earthy, but other music, generally remastered stuff, it can sound a bit mechanical.
__________________
Electro
Electro's picture
No nothing to do with the speaker crossover .
Here is a good explanation .
http://www.electronics-tutorials.ws/amplifier/amp_7.html
__________________
chebby
chebby's picture
I can get my head around 'analytical' (just), but you've totally lost me with 'organic', 'earthy' and 'mechanical'.
As for Harbeths, the designer has always said (over and over again) to use any amplifier that is working properly and is operated within it's designed limits.
I'm pretty sure your Leema will be fine.
__________________
Electro
Electro's picture
One thing I will say is that if you listen to a well designed class A or high bias class AB amplifier then the absence of crossover distortion is very obvious IMHO Smile
__________________
plastic penguin
What I mean by "earthy" or "organic", think of vegetables. Organic veg should be grown naturally and therefore taste natural. There you have it "totally natural" sounding amp. Play disco types songs, acoustic stuff and it sounds great. However, its achilles heel is female vocals like Adele, Joss Stone or Simon & Garfunkel (remastered), Beatles (remastered) and it sounds a little cold.
Perhaps that's the compromise... don't really know, hence the question.
__________________
BenLaw
BenLaw's picture
Why don't you a demo a class A amp with your speakers? Then you will see whether it improves the music you describe. Personally I would have thought you'll have more room for improvement, and certainly more scope for a different sound, by changing your speakers. Which I thought was what you were looking at doing anyway?
__________________
HiFi   /   A/V   /   Bedroom
Covenanter
Covenanter's picture
Without trying to be rude, and apologies if you think it is, why did you buy it if it sounds "cold"?  Didn't you audition it?
Chris
BenLaw
BenLaw's picture
Or go for something like this:
(Technically a fruit, I know, but you get the idea.)
__________________
plastic penguin
Chris
Not rude at all - as I mentioned before all equipment below silly money is going to be compromised, and the speakers I heard improve a wonderful amp. Therefore just gauging opinion on how far one thinks an amp of the Leema quality can be taken (or how close to Class A or valve amp). The other reason for mentioning Harbeth or even Sonus Fabers...
__________________
