9 posts / 0 new
Last post
admin's picture
Last seen: 6 hours 32 min ago
how to connect subwoofer
Hi there,
can anyone guide me in connecting my active subwoofer (wharfedale  diamond sw150)  I have yamaha rxv 1065.
Andrew Everard's picture
Last seen: 3 years 3 months ago
Re: how to connect subwoofer
Phono cable from receiver's subwoofer out to the subwoofer's line input. Job done.
Anonymous's picture
I tried that its not working.
Anonymous's picture
Hello Andrew,
What cable should I use
Ronald Archiebald's picture
Last seen: 3 years 10 months ago
zan_01:
Make sure it's from the 'pre-out' section of the receiver.
zan_01:
Any dedicated subwoofer cable will do the job nicely.
As already mentioned, any dedicated phono-to-phono single cable will do. Every cable manufacturer has at least one in its range.
Anonymous's picture
Thank you all for your support.
Also worth checking that the subwoofer output on the receiver is on, that the level isn't set too low on either the receiver's subwoofer channel or the subwoofer, that there's enough level to trigger the automatic power/standby to switch on (or that the sub is in 'on' rather than 'auto' mode), and that whatever you're playing actually has some subwoofer content.
Log in to post comments
