High quality interconnect to power amp too? Need a new one then!
8 replies [Last post]
siac
siac's picture
Hello, your help much appreciated...
Does the integrated to power amp interconnect need to be the same as you'd use on a cd connection? It's only feeding the bass part of the bi-amping, isn't it?... so isn't that omni-directional and any bog standard interconnect will do? I have drawers full of them.
After a long time thinking of upgrading, I took the plunge on a used Tag McLaren set up. I'm very happy but am wondering if I'm losing out now with the previous system interconnects?
I have two higher quality interconnects, using Chord Cobra (original!) and Atlas Equator (old version not sure which). Equator between integrated amp and power amp, Cobra between cd and streamer.
If I'm wrong about the integrated to power amp scenario, I'll need a third interconnect as I'm currently swapping between cd and streamer, which is annoying.
System is Tag 60i and 60P with Tag CD20R, Kef Reference 2.2's and a CA StreamMagic 6 streamer. Interconnects as above.
Thanks very much in advance!
CnoEvil
CnoEvil's picture
RE: High quality interconnect to power amp too?
IMO. There are no hard and fast rules on this, and the people who don't believe in the benefits of I/Cs will tell you it will make no difference.
As far as I'm concerned, the best i/c should go from your source....a better i/c will improve matters between the amps, but hasn't quite as big effect.
I believe the i/c carries the full stereo signal, but it's just the bass part that is separated at the  crossover. The quality of the bass is imo effected a bit by the i/c (but more by the amp), and I think I am right in saying that it is only the sub-bass that is omni-directional.
So to sum up, use the best I/Cs you can afford (within reason), with the better one for the source if there is a difference.
__________________
"Everything has been said before, but since nobody listens we have to keep going back and beginning all over again."  André Gide
Big Chris
Big Chris's picture
I personally believe you should use the same I/C between source/amp & amp/power amp. I ditched my old I/C when I got my power amp and bought two pairs to replace it.
I wouldn't want any tonal variations or gain level differences between the two amps, however slight.
__________________
Hi-Fi: Arcam A85, P85, CD192. B&W 602S3, PV1, Grado SR125, Atlas Titan, Hyper 2.0.
A/V: Sony KDL-V40A12U, BDP-S760, Humax Youview, Onkyo TX-SR875, B&W MT30 7.1, QED HDMI-P, S.A XT
Alears
Alears's picture
I 'd have to agree with cnoevil. It looks like you are doing what he suggests anyway with the Chord going to source.
For the sake of 'oneness' I would eventually aim to use one make of cable in a system.
__________________
Origin Live Aurora Gold+Illustrious Mk2 arm+Zyx R100-02/Stello CDT200+Stello DA220 Dac/Tom Evans Groove Anniversary/Tom Evans Vibe Preamp/Linear A power amp/Acoustic Zen Adagios/ Chord cables
siac
siac's picture
All comments make sense, thanks!
I might try some swaps and borrow some I/C's then.
Anyone got a Chord Signature lying around ? Laughing
CnoEvil
CnoEvil's picture
If you are looking at that level, try to borrow some Telurium Q Black.  shifty
__________________
siac
siac's picture
No, not at all... Just being cheeky Smile
CnoEvil
CnoEvil's picture
So was I!  >)
__________________
Alears
Alears's picture
Yes I have as a matter of fact. Smile
__________________
