Hi Res music
14 replies [Last post]
stevebrock
stevebrock's picture
I have finally got some hi res music (24/96)
The Eagles - Hotel California
Stevie Wonder - Talking Book
Have both these albums streaming from an iMac to a SBT then into a Rega DAC via optical......
It hasnt blown me away with more detail but it almost sounds like vinyl but its very smooth, clear and enjoyable - like it a lot! is this what Hi Res is about?
__________________
Synology DS212j > Rega DAC > Rega Brio R > Rega RS3
Rega RP6 / Exact / Groovetracer SubPlatter
Chord Chameleon Plus / Rumour 2
Panasonic TX-P50 GT50 > BDP110e > Yamaha RX-V 667 > Rega Vox > Rega RS1
Hi-FiOutlaw
Hi-FiOutlaw's picture
RE: Hi Res music
Funny the way you put this down... I fell the same exact thing with my hi-res files, may be due Rega DAC, but I often said to my self (never had the courage to post it here like you did) that sound exactly like vinyl...
If we are the only two what the hell...
beauty, eh
__________________
Livingroom
Rega RP3 / Goldring 1012gx # Synology DS213 > QED Performance USB > Rega DAC > QED Performance RCA > Rega Brio R > Supra Classic 2x4mm > Dynaudio Excite X12 and some times BK XLS200 MK II
Bedroom
SBT > G&BL teflon line RCA > NAD 3020i > Supra Classic 2x4mm > Monitor Audio RS1
stevebrock
RE: Hi Res music
To be honest I did not know what to expect with 24/96 files - All I know is that those 2 albums sound fantastic.
But most of my vinyl sounds fantastic too, which got me thinking I should invest in an RP3!
O god hifi is soo addictive!
__________________
Hi-FiOutlaw
RE: Hi Res music
In white...  ohhh sure  twisted
__________________
Livingroom
Bedroom
krish123
krish123's picture
RE: Hi Res music
hi guys im intrigued as to what are 24/96 files can u download them in this format or what? is this format better quality than cd's ?
Hi-FiOutlaw
RE: Hi Res music
For me the quality is the same as the CD, but will depend on your DAC, as digital files need a treamer and a DAC to sound in it's best! Or a PC and a DAC.
And yes you have to down load in that format.
__________________
Livingroom
Bedroom
SteveR750
SteveR750's picture
RE: Hi Res music
Get a copy of the 24/96 version of Rumours - you will be blown away, but that's most likely down to a better remaster rather than the (debatably) superior SQ of hi res.
__________________
JRiver MC17 -> Cambridge Audio DACmagic+ -> Roksan Caspian M2 -> ProAc D18
stevebrock
RE: Hi Res music
where from in the uk?
__________________
SteveR750
SteveR750's picture
RE: Hi Res music
That bit I can't help with I'm afraid. I got mine from HD tracks just before the shutters came down.
__________________
CJSF
CJSF's picture
RE: Hi Res music
For what its worth, I have had a couple of sessions over this weeken on line . . . I subscribe to 'Spotify Unlimite' . . . some of the music I have been listening too has blown my mind!  My DAC is a tiny HRT no bigger than a fag packet.  I find the older recordings 80's and older are so much better?
In particular, a mind sticker; Karl Denvers album 'Wimoweh' great 60's music. Try Ladysmith Black Mambazo, some amazing African style acapela music that draws you in . . . if you let it.  I dig around a lot in Spotify, diping in to albums, there is some real dross, but in there are some real gems if you give them a chance . . .
I put the SQ I get from Spotify down to the HRT DAC.
Purley my opinion and personal findings.
CJSF
Craig M.
Craig M.'s picture
RE: Hi Res music
+1.  The switch to 24 bit increases the potential dynamic range, but 16 bit already has a higher dynamic range than any stereo.  The higher sample rate just means that higher frequency sounds can be captured, but 44.1 gives higher frequencies than you can hear (unless you're a teenager, maybe) and your kit might not be able to play them anyway.
They can be worth it though, for the better remasters.  They're not always better though, sometimes just different - Nirvana Nevermind being an example.
__________________
Synology NAS + Audio Station - ATV2 - Benchmark DAC1 HDR - Event Opal
http://nwavguy.blogspot.co.uk/2012/04/what-we-hear.html
The_Lhc
The_Lhc's picture
RE: Hi Res music
Yes but it's not quite that simple is it? CD might be capable of that kind of dynamic range but it isn't being used. We all know about the "loudness" wars, with dynamic range being compressed to within an inch of its life. That doesn't appear to be happening with 24bit recordings, so it's entirely possible that a 24-bit recording WILL have a greater dynamic range than the equivalent CD, not due to anything inherent in the format but simply because more care is beng taken.
Now, if this prompts mastering engineers to do the same for CD issues (however long they continue for) then your point will stand and of course, we'll all be a lot happier for it!
__________________
No signature worth mentioning...
Craig M.
Craig M.'s picture
RE: Hi Res music
Did you actually read what I'd posted?  I selectively quoted Steve's post to isolate the point about the remaster and gave it a +1, and also mentioned that the 'hi res' music can be worth downloading for the better remaster.  I thought I'd made that clear?  None of which has anything to do with the greater bit-depth on offer because even the 'hi res' downloads are, dynamically, nowhere near the limits of 16 bit material.
__________________
The_Lhc
The_Lhc's picture
RE: Hi Res music
Craig M. wrote:
The_Lhc wrote:
Yes but it's not quite that simple is it? CD might be capable of that kind of dynamic range but it isn't being used. We all know about the "loudness" wars, with dynamic range being compressed to within an inch of its life. That doesn't appear to be happening with 24bit recordings, so it's entirely possible that a 24-bit recording WILL have a greater dynamic range than the equivalent CD, not due to anything inherent in the format but simply because more care is being taken.
Yes, did you read mine and if so, what makes you think I was having a go at you? I was just expressing the point that engineers have ignored the dynamic capabilities of CD for decades, so its capabilities are almost irrelevant if they aren't being used. That's it, that's all I said, so what's with the attitude? I was agreeing with you for EDITEDs sake...
__________________
Craig M.
Craig M.'s picture
RE: Hi Res music
Sorry, I think we're at cross purposes here.  You said it's not that simple, I think it is - the improvement is down to the master not the format.  Which I think is all I said in my post, along with a brief explanation of what 'hi res' audio files actually are, ie: not hi res as most would understand the term.
__________________
