Help! Is Uniti Lite best low budget solution for my system?
21 replies [Last post]
harry_t
harry_t's picture
Hi all!
My hi-fi consists of a pair of Triangle Celius 202, a primare cd21 & an integrated amplifier primare a30.1. I would like to be able to stream music from a NAS in the same quality in terms of sound or slightly better than i do now in my current system. Given the fact that in 5 years time my amp will be 15 years old, is the purchase of Naim's Uniti Lite the best low budget solution for my hi-fi system now?
Thank you in advance,
Andrew Everard
Andrew Everard's picture
Online
RE: Help! Is Uniti Lite best low budget solution for my system?
I'm not sure the UnitiLite would be the best solution for your needs, given that you're going to be doubling up on CD player and amplification in order to get streaming capability.
Perhaps something like the Award-winning Cambridge Audio Stream Magic 6 would be a better bet, not to mention less expensive?
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
harry_t
harry_t's picture
Thanks a lot Andrew !
i suppose i will have to compare it with Uniti Lite in terms of sound quality. I have one question though, will Audio Magic 6 have the ability to succesfully handle sample rates up to 192kHz from a NAS? I will store in NAS mostly wav files
Regards,
Harry
Andrew Everard
Online
No, the Stream Magic only goes up to 96kHz.
Frankly, if you want 192kHz capability, I'd suggest the Naim ND5XS would be better for your system than the UnitiLite – no CD/amp duplication, and it sounds considerably better. Or if the Naim price is a bit rich for you, the Musical Fidelity M1 Clic would be a good choice, although it'll only do 192kHz via a wired connection, or up to 96kHz wirelessly.
__________________
Shanka
Shanka's picture
Would the new Naim V1 DAC be similar in SQ to the ND5XS, it is less than MF Clic, depends how the NAS will be controlled if it were to be suitable option.
__________________
Roksan Caspian M2 cd/amp ; Proac Studio 140 Mk 2
Ariston RD11s SME 111 AT95e Rega Fono MiniA2D Arcam Alpha 9 B&W CDM1NT
jjbomber
jjbomber's picture
Shanka wrote:
Hi, Would the new Naim V1 DAC be similar in SQ to the ND5XS, it is less than MF Clic, depends how the NAS will be controlled if it were to be suitable option.
He wants a streamer, not a DAC.
The real question is whether a ND5 XS through a 10-year old Primare amp will sound better than a Uniti Lite? There probably is that there isn't anybody in the World who will have hooked up the former, so it will be a case of getting a demo organised. The second part of the question is cost. The ND5 XS retails at £2,000 and the Uniti Lite at £1,650 (and he can sell the Primare if he wishes). It's a classic sound per pound test.
BigH
BigH's picture
I'm looking at similar solutions at the moment, would the Sonos system not work. For me I have a computer, wifi, dac, amp and speakers, I'm considering Sonos but £250, would a Roku box work?
harry_t
harry_t's picture
Let's say i choose the option of a quality streamer such as Musical Fidelity M1 click (or ND5 XS) than an economic all in one system (such a Naim Uniti Lite). What about my current amp? How many more years can i keep it in good condition? 5 more years i think will not be a problem i suppose...(in 5 years from now my amp is going to be a 15-years old device) Any suggestions for a new amplifier that best suit my needs without changing my Celius 202 in the future?
Regards,
Harry
Singslinger
Singslinger's picture
The Pioneer N-50 streamer might be worth exploring, though I'm not sure if it streams 192kH.
Singslinger
Regards,
Harry
If you do go for the Clic, then for an amp I would suggest the matching Musical Fidelity power amp and to use the Clic as a preamp.
BigH
BigH's picture
Singslinger wrote:
Regards,
Harry
The M1 is only 65W, for your speakers you may want something with a bit more power, I believe your current amp is 100W?
harry_t
harry_t's picture
Yes you are right 100watt...but i don't know very much about the comp pre-amp & power amp though to have any opinion...
Regards,
Harry
harry_t
harry_t's picture
Hi again Andrew!
What about Naim Uniti? Is it a better solution for my needs?
Thanks,
Harry
Shanka
Shanka's picture
If you use the MF Clic you can always use a second M1 pwr if one is not giving you the oomph you need.
The other option is the naim 172xs streamer preamp and then you can add an additional naim power amp when the time comes to replace your amp.
__________________
chebby
chebby's picture
Online
Power should go a bit further with the Triangle Celius 202 speakers than many others. They are 92dB @ 8 Ohms and have a minimum impedance of 5 ohms. (A pretty easy and benign load on paper at least.)
I guess we also need to know the listening distance and maximum volume levels you prefer.
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
jjbomber
jjbomber's picture
You can call this number 2.
