5 posts / 0 new
Last post
2ptjoe's picture
Last seen: 3 years 8 months ago
Hello, and help please
First off a hello from a newbie, and i do mean newbie to hifi , as well as the forum.
I,ve been looking at building a system up for some while now  but my total lack of knoledge has held me back.
What do i want ? Well , i want to play my old records is a main thing, then CD,s . Now, i thought i was getting the hang of what an amplifier was, as in i needed an intergrated amp so i,ve been looking around for Arcam  units on ebay , something like the Alpha 8 was looking good for me, but now i find out that these dont always support a turntable ?
I really dont know the heck what i am doing here, so can you intellegant lot on here please help a newbie build a system  that can help me get back to my 80's record playing happy days .
Budget ?
Well if i knew what i was doing then i,ll go for around £1000 for amp, cd , turntable and speakers which i understand is not alot but we all have to start somewhere !
Thanks in advance
tomlinscote's picture
Last seen: 2 years 5 months ago
RE: Hello, and help please
Do you already have a turntable if so does it have a line level output  the answers will make a difference to potential replies
for ex if you do have a TT with a line level output you can go straight to a line level input amp plus speakers and cd so maybe marantz and monitor audio kit, if not you could start with a Project TT the Debut series has (or at least used to have) line level out for about £300 that leave 700 for the rest which is getting tight....
Tommo
BigH's picture
Last seen: 2 days 2 hours ago
SOme amps do not have phono stage but some of the Arcam have phono stage added as an optional extra, so look out for those, the Alpha 9 is meant to be step up from the 8 but is about £200-£250, try to get a refurbished one if you can. You could probably get a Marantz 63 KI cd player for about £100. Not sure about turntables let someone else answer that. Speakers Mission 751 maybe? Do you want floorstanders or Standmounts?
Listen to the music, not the hifi.
2ptjoe's picture
Hi guys.
At the minute i,ve nothing, no amps, turn tables, nothing.
Phono. Right, it needs to have phono added to it. Thanks guys, but you can see how basic i am in what i know. That said it,s going to be a fun experience !!!
ANY advice is both needed and greatfully received and with a little luck i,ll keep this open so i can add to it as i buy my first system based on peoples advice.
Edit"
As for speakers i,m easy on that to.
BigH's picture
TT Project TT or Rega for about £200.
Amp. Arcam, NAD, Yahama for about £100-£250. Or Linn for £300.
CD Marantz 63SE KI or 52SE for about £100.
That would leave about £500 for speakers which is prob. the most difficult and will make the biggest difference to the sound.
Really its best to try and hear some systems to get an idea of what you like. There are a few second hand or dealers that have used gear that maybe in your area. I know of some in Kent, Herts and Norfolk. If not you can hear new stuff.
Log in to post comments
