Have you ever had two different brands operating on the same remote channel?
Mon, Jan 7 2013, 5:46PM
My Plinius amp and Arcam AVR operate off the same remotes causing all sorts of inconvenience. Is there a way to change the channel of one?
BTW - Plinius never respond to any emails and over the years I've sent loads with no response. Pretty shoddy.
Mon, Jan 7 2013, 6:10PM
#2
Yes.
Different brands often use the same code, but it can have different functions.
Arcam usually have the ability to change the code (see manual)....but you have to change at the contol, and at the component.
Mon, Jan 7 2013, 6:17PM
#3
Yes my rocksan caspian remote will turn the volume up and down on my m6i amp but the m6 remote will not skip tracks on the cdp . I have had the problem you discribe and its a real pain when you switch one unit on and they both go on or one goes on and the other goes off
Mon, Jan 7 2013, 6:33PM
#4
Yes - my old Marantz CDP remote also worked the volume & mute on my Brio R which was a benefit!
Synology DS212j > Rega DAC > Rega Brio R > Rega RS1
Rega RP6 / Exact
Chord Chameleon Plus / Odyssey 2
Panasonic TX-P50 GT50 > BDP110e > Yamaha RX-V 667 > Rega Vox
