29 posts / 0 new
Last post
paulb22's picture
Last seen: 3 years 9 months ago
Good Turntable/Speaker/Amp beginner setup
Hi, apologies if this is in the wrong place.
I've become interested in collecting vinyl records, and am looking to get a good turntable/stereo and amplifier setup (I've heard I may also need a pre-amp as well).  I live in the Manchester area of the UK, and my budget is about £400.  All I want to do is to listen to vinyl on it, nothing like Dj'ing or anything like that.  By most record shops I've contacted I've been advised to get my setup from a company called Richer Sounds, which apparently do speaker and amp bundles.
Thanks in advance for the advice.
Paul
stevebrock's picture
Last seen: 6 days 19 hours ago
RE: Good Turntable/Speaker/Amp beginner setup
i would advise 2nd hand if your budget is £400
Start with a used Denon/Marantz/Nad amp with built in phono stage (this amplifys the Turntables output)
Maybe a used Project Debut TT
If you could stretch your budget a bit more then it would pay dividends!
Black Gyro SE / SME IV / Primare I32  R32 / AT33 PTG II / ATC SCM11
paulb22's picture
I could maybe stretch to about £500.
I've looked at your recommendations is the Marantz 5004 (which has built in Phono Stage) an amp worth getting.  Not sure about the turntable, even used it might stretch out of my budget, how about speakers? Any good recommendations
chebby's picture
Last seen: 1 day 41 min ago
paulb22 wrote:
I've become interested in collecting vinyl records...
Is it too late to stop?
iPad Mini 3 • iPhone 6 • B&W P3 • Mac Mini • Apple TV3 • Quad Vena • Pro-ject Tuner Box S • Audio-Note AX-Two
paulb22's picture
Well yes, I like the idea of collecting vinyl records, hope that answered your question.
jcarruthers's picture
Go secondhand — don't spend too much and see if you like it or not.
If you don't like it you can flog it.
If you love it then you can look at flogging it and upgrading.
Either way you won't have wasted much money.
Blackdawn's picture
Last seen: 1 month 1 week ago
Heres a new system that would fall in budget.
Denon PMA520AE - £139.95 - Richer sounds
Q Acoustics 2020i - £164.99 - Richer sounds
That leaves around £200 for a turntable - e.g. Project Essential turntable
HiFi - Cambridge Audio 340C, Pioneer A30, Denon TU 260L, Dali Lektor 2.
Vinyl requires a lot of commitment!
The rewards are there if you take the time to keep things clean, look after your vinyl (clean then pop in a Nagaoka Anti Static Sleeve) brush every side before you play etc etc not forgetting the fun part of scouring used record stores & fairs.
I have best of both worlds, but my vinyl is my main source with digital not far behind!
Excellent!! Go for a Rega RP1 though!
matthewpiano's picture
Last seen: 4 days 23 hours ago
Yep, you won't go far wrong with the Denon/Q Acoustics pairing, but I agree a Rega RP1 would be a better bet than the Project.  Should be a cracking system.
Rega RP3/Elys2/TT PSU- Denon DCD720ae - Denon PMA720ae - Dynaudio DM2/6 - Atlas Equator 2.0 - Beyer DT-770PRO - Mission stands
Joshuamessenger's picture
Last seen: 3 years 2 weeks ago
I found the rega dull and unentertaining with no real drive, what did come as a shock to me as i when in with the full intention of buying it. After testing the project SE3 the music come alive with personality and musical drive. i did test in shop with following equipment,
Sugden A21SE Amplifier
Project Tube Box MkII Phono Stage
Monitor audio gx50
paulb22's picture
What cleaning methods can be used, I've seen many different videos on YouTube but all seem to have their own method, what would you recommend
If I get the Rega RP1 is the stylus and cartridge upgradable later down the line.
Thanks for all the great answers and advice
Sorry... just to add I’m sure the RP3 is a cracking model and would put my table to shame
The RP1 will accept another cartridge yes, but you can only take the deck so far before you start spending more than the deck is worth!
I think the RP1 with performance is more than adequate for a newbie, if you take to it save for a better deck!
I was warned by a mate that if I got into vinyl it would be expensive.....he was right I am on an RP3 and just about to pull the trigger on an RP6 and yes i am addicted to vinyl!
paulb22's picture
Hey guys, thanks for all the help, got my turntable amp and speakers yesterday, i'm about to set them up tommorrow.  I take it the turntable usually connects into the amplifier and then the amplifier connects to the speakers?  Cheers, Paul
TubularTechnician's picture
Last seen: 2 years 3 months ago
Yep thats it. (Feels strange giving advice as I'm a newbie too Smile  , but not to many people about tonight)
I'm loving listening to my old vinyl again. Can't believe I was in John Lewis today and they're selling vinyl. Not much, but reasonably cheap. £20 for an LP and matching CD combo.
Pages
Log in to post comments
