9 posts / 0 new
Last post
gooner26's picture
Last seen: 3 years 5 months ago
Good quality cheap 3.5mm to 2 phono cable?
I'll be needing this for a connection between a Phono amp and Stereo amp!
They have some really cheap ones on Amazon, do not want it to degrade the sound though.
Best
Danny
mjcmt's picture
RE: Good quality cheap 3.5mm to 2 phono cable?
I'd step up from the really cheap stuff and get an entry cable from someone like QED. Or direct from a company like Monoprice that makes their own.
http://www.monoprice.com/products/search.asp?spcDB=10218&spcWord=Audio+Cables+%2D+RCA+%26+3%2E5mm&keyword=3.5mm%20to%202%20phono%20cable
MajorFubar's picture
Last seen: 14 hours 28 min ago
There's ten billion on eBay and Amazon. Avoid the dead cheap ones which are poorly made and won't last five minutes.  Having dispensed with those, take your pick from any of the rest. And don't worry about the sound. Despite what some crazed lunatics will tell you, the good ones will all sound so nearly identical that there will never be a time when the sound-quality of the cable will be a limiting factor. When you've done what I have done, and lifted the lid on your highly-regarded HiFi amp only to find critical parts of the audio-chain are linked to each other by computer-grade ribbon-cables (which presumably do the job perfectly well), you'll realise that worrying about which interconnects are hanging out the ar$e-end is futile.
Audio: MacMini / AEX > AVI DM10 + BK Gemini II sub; Visual: Samsung BD-C5500 > Panasonic TX-L47ET5B.
Head-fi: various, but most often Sennheiser HD-580 or Audio Technica ATH-M50X
bigboss's picture
Online
Last seen: 3 hours 48 min ago
I would recommend Fisual. Brilliantly made at a good price:
http://www.amazon.co.uk/Fisual-Install-Series-3-5mm-Phono/dp/B001FZSMPO/ref=sr_1_1?ie=UTF8&qid=1375054165&sr=8-1&keywords=Fisual+3.5mm+to+phono
Good choice BB, that looks perfectly up to the job imo.
pauln's picture
Last seen: 3 hours 47 min ago
:cheer:
:cheers:
RobinKidderminster's picture
Last seen: 2 months 3 weeks ago
I have a long length of Fisual and it works!
Yamaha V2065. MS Mezzo 5.1 Panasonic 42. Sony BD. Garrard 86SB. WD Live TV. SkyHD.
http://www.whathifi.com/forum/home-cinema/lounge-hc-signature-update-bass-traps
TrevC's picture
Last seen: 1 month 2 weeks ago
Any lead will work fine, ie the same. Get a quality one if you are likely to be unplugging it all the time.
MakkaPakka's picture
Last seen: 1 year 1 month ago
This one:
http://www.amazon.co.uk/Belkin-iPhone-Adapter-Cable-3-5mm/dp/B000ZZQAVI/ref=sr_1_5?s=electronics&ie=UTF8&qid=1375091059&sr=1-5&keywords=belkin+3.5mm+to+phono
I use a similar Belin one for my headphones as they aren't stiff where the wire meets the plug so can take a lot more wear and tear.
Log in to post comments
