16 posts / 0 new
Last post
bigfish786's picture
Last seen: 1 week 6 days ago
Focal tools.. any experience?
has anyone ever used this? and is it any good?
i'm thinking about having a play around tomorrow.
http://www.focal.com/en/content/437-position-of-hifi-stereo-speakers
Marantz TT15S1. Leema Pulse. Moon Equinox. Focal Chorus 826V. Nagaoka TS12. Clearaudio Virtuoso. Musical Fidelity MF100. SONY KD65XD7505 4K TV.
plastic penguin's picture
Last seen: 6 days 19 hours ago
RE: Focal tools.. any experience?
The link doesn't work.
What is the specific problem?
Leema Pulse; Arcam CD73; PMC TB2i; Pro-ject Xpression with a ClearAudio cart; Denon TU260 MKII
chebby's picture
Last seen: 7 hours 40 min ago
The link works but it's the wrong link.
This is the one for Focal tools...
http://www.focal.com/en/content/571-focal-tools
iPad Mini 3 • iPhone 6 • B&W P3 • Mac Mini • Apple TV3 • Quad Vena • Pro-ject Tuner Box S • Audio-Note AX-Two
TBPH, dunno. I suppose it could come down to price. If it's a cheap as chips it maybe worth it, otherwise put on a favourite track and just judge it.
Are the speakers booming or too trebly? If you could tell us the problem....
RobinKidderminster's picture
Last seen: 3 months 3 weeks ago
Listening to sine waves is somewhat similar to listening to some modern music  Smile Not that interesting.
The issue really is firstly how are u measuring the sound from the test tones and secondly what do u do about it. PP is right unless u are seriously measuring response and are willing and able to make changes.
As PP asks - what are your perceived issues?
Yamaha V2065. MS Mezzo 5.1 Panasonic 42. Sony BD. Garrard 86SB. WD Live TV. SkyHD.
http://www.whathifi.com/forum/home-cinema/lounge-hc-signature-update-bass-traps
akrapovic58's picture
Last seen: 3 years 5 hours ago
I think this is basic speaker setup.
In my local audio store the guy was applying the [3 = 1 = 2] and [tweater = ear hight] rule every time again.
So not only changing the cables to other speakers but also relocating them over and over again.
When I asked him why he did this, he told me those where the two most basic Hi-Fi rules...
[figure F] is also very important. Speakers need space to breath. Space will influent mainly the lower frequencies (aswell as the accoustics of the room)
So yes, this is very important    Dance 4
Fig F is so important there is no expaination for it ! These measurements depend on room size/shape I believe.
I have no specific issues at all guys, i was just wondering if anyone had used the focal tools to set up their own speakers? or anything similar?
i'm going to burn a disc today, just to see what sort of results i get.
because i've basically got all new components i just want to make sure i'm getting the best performance. (ocd)
Watch this - it may help (5.20 speaker positioning)
http://www.whathifi.com/video/get-the-best-from-your-hi-fi
andyjm's picture
I can highly recommend 'room equalisation wizard' (REW). Free software, which with the addition of a couple of inexpensive bits of hardware allows comprehensive room and system analysis.
Playing a few tones through your system without measuring equipment will be fun, but thats about all.
+1 & +1. Google louspeaker distance from wall - gives a good range of articles which whilst sharing common ground. also explains from slightly different perspectives.
Just play around with everything... The only one who will not like you turning your living room upside down is your wife   :cheer:
well, i downloaded the Focal tools files and burnt a cd. i put it in the rega, i think it was a bit too much for the poor thing, it didn't like it one bit, so i put it in the Arcam Dv79 and played it... 20 mins of noise later and i'm none the wiser. oh well, thats an hour of my life i wont get back.
one surprise was the Dv79 with a music cd in it. with the leema amp it actually sounded half decent. so thats a bonus.
How does the Arcam compare to the Apollo?
You were warned.  Smile
The Arcam is not bad, but its not great either. partnered with the arcam amp it sounded very digital, itchy! it didn't sing. i'd replaced an Arcam dv88 as the dv79 has hdmi. the dv88 was far better with music. so, i always considered the Dv79 the weak link, and was the first piece of kit i upgraded.
the Rega Apollo is better in every way. an absolutely marvelous piece of kit. for producing music it is the dogs wotsits. it can be a bit temperamental, it doesn't always do what it is supposed to do. but i think that makes me like it even more!
if i were to replace it, i'd definitely go rega again. possibly the saturn-r. the sound is addictive. i've probably doubled the amount of music i listen to since buying it, it had that much of an effect.
Log in to post comments
