Equipment Connection Help
Hi there, I currently have two set-ups in my home studio. One is for production which comprises of KRK rp5's and KRK s10 sub. The other is for DJ'ing and is a Yamaha As500 Amp running into a pair of monitor Audio Rx1's. Both are connected to the KRK ERGO Room Correction System.
I'd like to be able to share the sub between systems. I currently don't use it for DJ'ing. I was thinking of keeping the production set-up as is (ERGO to SUb to Monitors using XLR inputs/outputs of the sub), and then running the second ERGO output into the rca sub inputs and the the rca outputs of the sub into the Yamaha Amp.
I realise this isn't as intended and potentially could cause some serious problems/damage if both inputs of the sub were active at once. However, assuming the ERGO switches it's output as intended only one signal would be active at a time.
Is this possible?
Many Thanks in advance.
Dan
