Downgrading my speaker cables
14 replies [Last post]
Dommer
Dommer's picture
I've been using a pair of QED Genesis silver spiral Bi-wire cables for a few years with my system and I love the full sound they produce. However last year I've moved into a new flat and I just don't have the space to run 6 meters of thick bi-wire cable. Not to mention that since upgrading to the UnitiQute I no longer need the Bi-wire option. so I've put the QED cables on to a popular trading site (tree something) and am looking for new cables that would sound equally good but that would be more manageable to fit behind bookshelves. Any recommendations would be appreciated.  I'm running the Naim unitiQute with a pair of Kef R100s. Budget is about £200.
Thanks.
__________________
Naim UnitiQute, QED Genesis Silver spiral cables, KEF R100.
Audiolab 8200CD, QED reference silver spiral interconnects, ProJect head box Amp, Grado SR225
chebby
chebby's picture
Online
RE: Downgrading my speaker cables
Linn K20 about £5 a metre.
QED 79 strand £1.80 per metre. (Or thereabouts.)
Any other straight-forward, flexible, 'dumbell/figure-of-eight' type cable with good quality copper of reasonable gauge and no 'quirky' electrical properties.
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
Superaintit
Superaintit's picture
Hi Dommer,
IMO a Vandamme lc-ofc speaker cable is good value for money. Its aimed at the professional market and therefore more affordable. Will cost you about 5 pounds per metre.
the record spot
the record spot's picture
I ditched bi-wired Audioquest Type IV speaker cable (now around £13/m) for 322-strand cable, 10m of which came from Ebay for £5.50 delivered.  If anything, it was very slightly better than the AQ it replaced.  I now use 400-odd strand OFC cable.  Thoroughly recommend you explore this option (or the ones listed already) before splashing the cash when you might find you don't need to.  For the cost of a couple of drinks, it has to be worth trying out.
__________________
Onkyo TX-8050 / Tannoy Revolution DC4 / Marantz SA7001-KI / Apple TV 3 / Sony PS3 320Gb / Denon DVD-3930
tyranniux42
tyranniux42's picture
Linn k20 is a good shout, if you want to spend a bit more try naim naca5. Both will work great with the qute
__________________
Main System: Naim CD5XS or DAC Magic -> Naim Nait XS -> Naim Ovator S-400
2nd System:  Naim Unitilite -> B&W 602s3
Headphones: Naim CD5XS or DAC Magic -> Graham Slee Solo -> HD650
Home Cinema: Sony KDL 40D3500, Sony BDP s370, Sony DAV-IS50, XBOX 360, PS3 & PC all into DACMagic for passthru or decoding
CJSF
CJSF's picture
Linn K20, been using it since the 80's, tried others up to 10 times more expensive to no good effect.
__________________
Rega P5/PB700 (upgraded main bearing, white drive belt), Sumiko Celebration Pearwood Signature cartridge, Carver MCt, Croft Integrated Valve hybrid amp, PMC LB1's on Foundation Designer Stands, Rega Apollo CDp. Cables: speaker, Linn K20, Interconnect, Foundation Audio Special.
Singslinger
Singslinger's picture
I've had good results with Ringmat cable. They make only one model and it's not expensive (sorry I don't know the UK price).
Exoticsounds
Exoticsounds's picture
You could give Audioquest FLX-SLiP 14/4 a try.
MUSICRAFT
MUSICRAFT's picture
Hi Dommer
I feel that you should also consider using basic 79 multistrand OFC or at a push 500 multistrand OFC speaker cables.
All the best
Rick @ Musicraft
__________________
Musicraft (Derby), Specialist Hi-Fi/AV & Multimedia Dealer
good accurate audio monitoring and good sound reproduction to all Smile
Coll
Coll's picture
I agree QED 79 strand or QED Original or similar would work very well, I dont subscribe to spnding a fortune on exotic cables.
__________________
CJSF
CJSF's picture
I did do an A-B comparison Linn K20 v QED 79 strand, it was 30 years ago, I seem to remember the 'differeances; were marginal in favour of K20.  In those days it was just 1m runs from valve mono blocks.  These days, its an 8m run  banging head against wall
I have tried cables recently, out of curiosity because of the 8m run.  The differances were purely personal, still prefering the K20.  Because 'OFC 500 strand' is cheap I bought 2x 8m runs, my preferance means this lies rejected in a box in the shed.  I borrowed Black and Blue versions of Q cable from my local dealer, Blue did not work for me at all, Black was good but not good enough to justify £800!!  Personal preferance again . . . and a prod or three from my Hazel read this !!!!!  She has a good pair of ears . . . as I am finding out . . . I'm enjoying sharing my pasion for music and hifi with here cheer
Get into cables and you will tie yourself into knots with no real satisfying result . . . thats IMHO
CJSF
__________________
CnoEvil
CnoEvil's picture
CJSF
If that's your rather convoluted way of saying...get the Linn K20, then I agree with you.  Wink
__________________
"Everything has been said before, but since nobody listens we have to keep going back and beginning all over again."  André Gide
Dommer
Dommer's picture
Thank you everyone for the great recommendations. I will definately have a look into all the cables mentioned.
__________________
CJSF
CJSF's picture
CJSF
Yep Cno, you know me, 'never use one sentance when a dozen will do' . . . cool   The last sentance is the cruncher, ' . . . tie yourself in knots . . . '.
CJSF beauty, eh
__________________
CJSF
CJSF's picture
Deleted double post . . . ?????? CJSF
__________________
