20 posts / 0 new
Last post
admin's picture
Last seen: 1 day 3 hours ago
Does those isolation cones make any difference?
Anonymous's picture
RE: Does those isolation cones make any difference?
They cost so much. But does it really worth it? How to choose it? Thanks.
Overdose's picture
Last seen: 2 years 1 month ago
If you're talking about the solid little cones that go under a piece of equipment, then they don't 'isolate' anything. They merely provide a more solid and less forgiving base. Equipment in general is designed to cope perfectly well as is, straight out of the box.
People consider TT bases as requiring isolation, but even TTs have suspension by design, so just need to be stable.
CnoEvil's picture
Last seen: 3 hours 40 min ago
IMO. Experimentation is the key.
I think different materials have different effects, which is component and taste dependent.
There are soft isolation materials like Sorbothane, a variety of solid pointed feet (again made from different materials) and wood. An off-cut of plywood is cheap and worth a try.
There are a huge variety of products, which go from pretty cheap, to very expensive....my advice is to experiment with the cheap solutions first, and see the sort of effects you get from hard or soft materials.........do a lot of Googling around "Isolation" and "Decoupling".
"We should no more let numbers define audio quality than we should let chemical analysis be the arbiter of fine wines."  Nelson Pass
acalex's picture
Last seen: 1 year 2 months ago
I am very intrigued to try the Clearaudio Magix which is supposed to completely decouple the turntable from the platform...will get 3 of them next time to try and report back
Overdose's picture
They will not completely decouple the equipment. The guide pin will provide some mechanical interaction and Newton might have something to say regarding one of his laws. The devices will act as spring dampers and that is all. A partially inflated inner tube would be just as ineffective/effective, depending on how you percieve the problem or lack thereof.
Magix they may be, magic they are not.
basshound's picture
Last seen: 20 hours 19 min ago
Am I looking at the right things £235 each ? Seems a bit overpriced.
Synology DS213j NAS>JRiver 21 >Auralic Vega> ATC P1 >ATC SCM 40`s + BK Electrics Monolith Plus sub
drummerman's picture
Last seen: 5 hours 56 min ago
Relative.
Worth it if the TT is reasonably expensive and it makes a difference.  -  Expensive otherwise.
regards
CnoEvil's picture
drummerman wrote:
Relative.
regards
Sometimes it's good to hear a well engineered solution, and then try and replicate it with a DIY solution (half inflated inner tubes etc). CJ is a master of this.........though it may require the "tweakers' gene".
Singslinger's picture
Last seen: 1 year 4 months ago
I can't help but think of "The Cone of Silence" in the 1960s TV comedy Get Smart that agent 86 Maxwell Smart insists on using when discussing top secret matters with his Chief. It's an isolation device that's supposed to be sound-proof but of course, doesn't work at all! Those of a particular vintage would remember it well ROFLROFL
On a more serious note - I would agree that it's best to try what's out there. There are benefits to be enjoyed but best to audition for oneself.
andyjm's picture
Last seen: 2 days 21 hours ago
No matter how much you decouple or couple your turntable, it doesn't get round the problem that the pickup is designed to detect mechanical vibration, and the speakers are designed to produce it. Even floating on a magnetic cushion, sound waves will be impacting the turntable. If you have a solid concrete floor, there is an argument to have the turntable firmly coupled (solid table and pointy spikes) as this will damp any turntable vibration, rather than have the turntable floating about.
Now, I am no fan of turntables, but I have fiddled with them in the past in the days before CDs.  If you can, the best and cheapest solution is to have the turntable in a different room to the speakers. Not for everyone, but solves all this acoustic feedback business.
Anonymous's picture
Isolation mats can be expensive. I bought 2 squash balls, cut them along the seam welds and put the 4 domes under the feet of a Marantz 6000OSE KI and the soundstage expanded wonderfully. Job done for £4! Try it for the price of a Guiness in London!
RobinKidderminster's picture
Last seen: 2 months 3 weeks ago
I tried sqash balls. The shop refused a refund. But for a few quid I didn't regret trying. Good luck. Wanna buy 8 rubber hemispheres?
Yamaha V2065. MS Mezzo 5.1 Panasonic 42. Sony BD. Garrard 86SB. WD Live TV. SkyHD.
http://www.whathifi.com/forum/home-cinema/lounge-hc-signature-update-bass-traps
Are you saying they refused to take back the halfed squash balls ... ?
Outrageous
regards
BigH's picture
Last seen: 1 month 6 days ago
What colour dot squash balls did you use, are the red dots better than the double yellow?
Listen to the music, not the hifi.
acalex's picture
I can get them at 100 euro/piece. I think you are looking at the price of the miniMagix probably
Pages
Log in to post comments
