38 posts / 0 new
Last post
MCRetina's picture
Last seen: 1 year 5 months ago
Does expensive RCA cables will improve sound quality
I sure this have been discused before but:
Does expensive or brand RCA cables will improve sound quality of my sistem?
NAD 315BEE amp
NAD 515BEE CD
MA BR2
Audioques cable
Cheap RCA
Crossie's picture
Last seen: 3 months 1 week ago
RE: Does expensive RCA cables will improve sound quality
Here be dragons...
Yawn.
Just because you are paranoid does not mean that they are not out to get you.
Anonymous's picture
No. But it may provide a slightly different presentation. Have you A/B tested your cheap RCA vs. Audioquest? Wink
eggontoast's picture
Last seen: 21 hours 11 min ago
Oh no, here we go again.
Would probably be easier just to try a few to make up your own mind.
moon's picture
Last seen: 3 years 11 months ago
:wall: dull
Pistol Pete1's picture
Last seen: 5 months 16 hours ago
Yes they will......(ducking for cover!!!!!) :help:
Panasonic TX-P50X60 : Benq W1070 : Pioneer SC-2023 : Marantz CD63 MK II KI : Panasonic DMP-BDT320 : X Box kinect
KEF Q100/Q200C/3001SE : AE Radiance sub
tino's picture
Last seen: 3 days 12 hours ago
No they don't .. they just degrade the audio less. You may not even be able to hear the difference once you go over the £30 mark
SBT • Wadia 151 • Aliante PF
I did......defo difference when I replaced my £30 connector for a £66 one......
bigboss's picture
Last seen: 4 days 20 hours ago
Here's my recent experience with RCA cables.
I wanted one for my bedroom to connect my Sonos to Audioengine 2 speakers. There was a lot of static noise when I first tried a cheap £2.69 cable (I had not even begun to check audio quality). I contacted the ebay seller, who sent another one out. Same result. I then ordered a £16 cable which was better built. No static noise this time.
In a nutshell, I can't comment if there's an improvement in sound, but better built RCA cables definitely eliminate static. Of course, my view about HDMI cables are well known; I haven't noticed a difference.
the record spot's picture
Last seen: 1 year 11 months ago
They "might" perhaps.
And given as I've just removed a pair of Atlas Navigators and stuck in my old Computergear ones, let's just say I reckon I'll get more for the Navigators when I stick them on Ebay next weekend...and the remaining audio quality is as good as it was when the Atlas ones were plugged in.
To the OP, get a few, from megacheap to as much as you want to spend.  Make sure you can get the pricey ones on a sell-or-return basis and see how you go.
For me, the differences have been minimal and only really came to light when the changes that one partcular cable was supposed to make (thanks to a 5 star review in an unnamed title) delivered nothing of the sort.  The questions began after that.  For you though, make up your own mind; YMMV.
Messiah's picture
Last seen: 3 years 6 days ago
After years of various 'upgrades' I am also a sceptic about the improvements they offer. For years I told myself the £100 cable I had bought was better than the £20 one but my honest conclusion now is that there was no real difference. That I noticed.
Best thing to do is to demo for yourself and decide.
FennerMachine's picture
Last seen: 1 month 1 day ago
As has been said a well built cable will likely sound better than a super cheapo one.
But you might not need to spend a fortune to improve what you have if you are after a mild change in presentation.
I had interconnects that cost me £175.00 a pair and speaker cable costing the same for a pair of 2.5m lengths. These where at a discount from friend who was winding down his Hi-Fi business, they should have cost near double that.
Made a small but noticeable difference over the good quality cables I had before, £50.00 to £100.00 interconnects and £100.00 speaker cable.
Since changing my speakers and pre-amp I have changed my interconnects and speaker cable.
Speaker cable cost less than £100.00 total and interconnects cost less than £30.00 per pair.
The overall sound of my system is much more enjoyable.
I liked the system I had for a few years but tastes change as you get older.
I would personally put the improvements down to the main components I have changed rather than the interconnects.
Knowing what I know now I would spend the sort of money I spent years ago on cables/interconnects on other components or on more music. Possibly on better quality beer!
As others have suggested try some cables with a good returns policy. Only you can decide.
CA 751BD, Abrahamsen V2.0 UP, IPL Acoustics S2TLK, Samsung LE32R87BD 32"
MCRetina's picture
eggontoast wrote:
Oh no, here we go again. Would probably be easier just to try a few to make up your own mind.
I know, but I cant just borw them from the store, I have to buy them to test them.
The bigest problem  is that there is not a big HiFi community in Xalapa, Ver.  Mexico. To be honest the only brand that I can find here  is Audioquest and only one model (snake). If I would like something else I wil have to buy it in US and smuggle it.
Maybe for the next topic I sould ask something less controversial ........... abortion, religion maybe?
hammill's picture
Last seen: 5 days 14 hours ago
Smile Try suggesting one hard disk sounds better than another. That is even more fun.
You should be OK with them subjects......and politics of course.
The_Lhc's picture
Last seen: 4 months 4 days ago
Do expensive RCA cables improve sound quality
That's the same thing, just looked at from the other direction.
Pages
Log in to post comments
