7 posts / 0 new
Last post
shafesk's picture
Last seen: 1 month 1 week ago
diy record cleaning ideas
Dear forumites,
I just got back some vinyl that I had lent to my brother. They have been violated to say the least, been scratched and are dirty. Can't bear to listen to the silent tracks as they are full of pops and clicks. Can anyone suggest ways of improving it? Mind you, I cannot get a hold of record cleaning fluid and carbon fibre brushes in my country so home remedies would be nice.
Appreciate the help as always,
Shafin
ifor's picture
Last seen: 1 week 4 days ago
RE: diy record cleaning ideas
A local second hand record store recommends warm water, washing up liquid and a soft sponge.
"Inspired" Manticore Mantra TT, Technics SL-7 TT, Slee Reflex M phono preamp.  Cyrus CD Xt Sig.  iMac, Raspberry Pi c/w HiFiBerry Digi c/w Volumio or Rune Audio, Arcam rDAC.  Roksan Kandy LIII amp, Spendor A5 speakers.
The_Lhc's picture
Last seen: 4 months 1 week ago
Distilled water, isopropyl alcohol and a drop of rinse aid, there's lots of people making their own mixtures on the web (I think JD does here as well), google for recipes.
MajorFubar's picture
Online
Last seen: 2 hours 27 min ago
What about the old woodglue trick...worth a try if all else fails?
Audio: MacMini / AEX > AVI DM10 + BK Gemini II sub; Visual: Samsung BD-C5500 > Panasonic TX-L47ET5B.
Head-fi: various, but most often Sennheiser HD-580 or Audio Technica ATH-M50X
BIGBERNARDBRESSLAW's picture
Last seen: 9 months 2 days ago
This is what you want
http://www.amazon.co.uk/CONRAD-Disco-Antistat-Disco-Antistat-Cleaner/dp/B000BFXIVW/ref=sr_1_3?ie=UTF8&qid=1356707474&sr=8-3
But whether you can get it in yourcountry is another thing.
Also, totally agree with the_Lhc on homemade fluid. I used this together with the Disco Antistat, and the results were fantastic, much better than expected. Even my most abused records are playable now.
Panasonic TX-P50GT50 / Yamaha RX-A2020 / Panasonic DMP-BDT110 / Dali Zensor 3 / Dali Zensor Vokal / Mordaunt Short MS20i Pearl Edition / Cambridge Audio Minx 11 / Tannoy TS2.10 / Roksan Radius 5.2 / Ortofon Super OM 20
CJSF's picture
Last seen: 2 weeks 5 days ago
Hi BB, do you use the rack supplied to let the records dry naturaly, I have read that some spin them dry in a 'drill?' .  Have also read the cleaning solution supplied is best not used leaving a residue, the home made concotions being much better?
CJSF
Anonymous's picture
Everyone needs complete satisfaction when it comes to the cleaning process of commercial kitchen hoods. It can certainly be a bothering and never ending process. So, you need to work really hard.  cleaners bournemouth
Log in to post comments
