Diasappointed with Naim Supernait and Spendor A5 combination
77 replies [Last post]
LionofJudah
LionofJudah's picture
For about a year ago i've bougth a Naim Supernait amp to combine with Spendor A5 speakers instead of a Arcam A85.  As player I use the Arcam dV88 wich is connected to the Dac of the SN. Love the prat and control of the SN. On the other hand i don't like the harsness in the mid-high and high. My room is L-shaped (living room and kitchen) with a total lenght of 8,5 meters. The living room itself is 5 x 5 meters. The speakers are placed at/near the longest wall. Reggae is the music I play for about 90% of the time. Is it the amp to blame? Or ar there any other suggestions?
CnoEvil
CnoEvil's picture
RE: Diasappointed with Naim Supernait and Spendor A5 combination
Hi there, and welcome to the forum.
I'm sorry you are not getting pleasure from your not insubstantial system.
A couple of questions:
- Did you hear the Naim and Spendor together before you bought them, if so, what has changed?.....and if you didn't, what did you hear them with?
- Could your room acoustics be contributing to the problem......ie. is it sparsely furnished, with a laminate floor and areas of tiles/glass?
- Are you using silver coated cables? - again, can add to the problem
Looking at your system, neither the Arcam or Spendors could really be described as harsh, which leaves the amp or the room acoustics.
One thing you could try, would be to borrow a different amp (like Sugden or Arcam) from your dealer, and see how that sounds.......and any "softening" of your room with rugs etc (if this is the problem) is worth a go.
__________________
"Everything has been said before, but since nobody listens we have to keep going back and beginning all over again."  André Gide
SteveR750
SteveR750's picture
I've heard similar comments from retailers on the SN - one reason why I didn't bother auditioning it in the end.
__________________
JRiver MC17 -> Cambridge Audio DACmagic+ -> Roksan Caspian M2 -> ProAc D18
LionofJudah
Hi CnoEvil,
No, I've heared the Spendors with Cambridge Audio 840 in a totally different room. And offcourse with my old Arcam A85 in my own living room.
It's not sparsely furnished but, yes, laminate floor ande tiles/glass. I have a carpet on the floor tough.
No, copper cables. I've also tried the Naca5 cable. No difference whats so ever.
jaxwired
jaxwired's picture
I've not heard the SuperNait, but I'm pretty sure the speakers are not the culprit.  Those Spendors don't sound harsh ever IMO.  They are very clean natural sounding speakers, although I'm surprised you are happy with the bass for Reggae music (maybe you have a sub?).
__________________
iTunes Lossless -> Airport Express -> Benchmark DAC2 HGC -> Belles 150a REF V2 -> Dynaudio Focus 340-> Chord Cables
CnoEvil
CnoEvil's picture
LionofJudah wrote:
Hi CnoEvil,
Did you hear the Naim sounding well with different speakers, or did you buy it on "reputation"?
It looks to me that there is probably not enough you can do with the room, so I'm afraid, that leaves the amp.....my choice would be a Sugden A21 SE,  Electrocompaniet ECI-5 Mk11 / ECI-3  or  Arcam A39 (if it is on the cards for release).
__________________
LionofJudah
No sub. Had one, a Rel Q150. Didn't hear much difference.
LionofJudah
Heard it with Harbeth SHL 5 and 30.
CnoEvil
CnoEvil's picture
Nice!
Well, that's your other option, unless the room's acoustics would tip that into harshness as well.......not easy, and only trial and error will come up with a solution that is tailored to the room, and your taste!
__________________
Native_bon
Native_bon's picture
I had this problem you having for years untill I invested in a proper mains conditioner!. Every time went to the shop listen to a system. Got home, sounded really horrible. Thin, bright & lacking body. Got a mains conditioner now my system sounds like I heard it in the shop.
Piont to note: But mains conditioners are a matter of try & see. In some cases makes some systems sound even worse. So its still a matter of trial & error. If u can get retailer to loan you one.
Also what hifi stand do you use?... If u using glass & steel Hifi rack this can make your system sound bright as well.
All the best.
__________________
No rules. If it sounds good to you it sounds Right!!.Transpor:t . Oppo BDP-105EU Blue ray player.DAC: Rega dac & Audio lab M-Dac. AMP; MARANTZ SR7007. SPEAKER'S; SONUS FABER CREMONA'S. (FLOOR STANDING) SYSTEM STAND:QUADRASPIRE. INTERCONNECT;CHORD CHAMELEON SLIVER PLUS. DIGITAL CABLE:Clearer Audio silver Optimus. SPEAKER CABLES: RUSS ANDREWS CRYSTAL-24... Mains conditioner: Isol 8.
Computer: Yototech: 600T case: graphice GTX690 Graphics card. 32gb RAM. Processor: I7 3960X. Solid state drive. 500gb. Sata drive 2TB. blue ray drive. studio monitors: Yamaha SH80M Active speakers. Mixer: Presonus studiolive 16.0.2. Audio connection Firewire via presonus. Screen: Asus 27inch VG278H
LionofJudah
All the best.
Main conditioners combined with Naim? That's a no-go. Had one and took it of. Sounded much better. I'm using a wooden frame. I think i'm going to try some other amps. And maybe another source.Trial and error.
Native_bon
Ok see. Wink
__________________
CnoEvil
CnoEvil's picture
I have the DV79, which is probably very similar to the DV88 for CD replay. It does a great job for a DVD player, but my Linn Majik DS makes it sound broken.
The reason I didn't mention it at this stage, is that the one thing it doesn't sound, is harsh......in fact quite the opposide.....a little on the dull and smooth side (compared to the Linn).
So what I'm saying is, yes get a good source, but look elsewhere for the harshness problem.
Cno
__________________
LionofJudah
Cno
I agree, had a Arcam CD192 before one of the dacs broke down and i loved it. If it had not i would be still playing with the Arcam combo. Thanks for your advice, all of you. Keep you informed.
altruistic.lemon
altruistic.lemon's picture
Online
Please! The Supernait is one of the best amps out there, irrespective of price. The DAC isn't, and that's the prob. Chuck using the SN DAC, gets yourself the new revised Nait CD5i, and she'll be apples!
CnoEvil
CnoEvil's picture
Good call, I didn't pick up that the DV88 was only being used as a transport.....
@LionofJudah
Maybe to start with, try using the Dac in the Arcam.
__________________
