22 posts / 0 new
Last post
stevebrock's picture
Last seen: 2 days 8 hours ago
DAB Tuner? PP some advice please
I want to listen to radio more, local sport etc etc
What are my options? Can I utilise my wireless to stream to it ?
How does it all work - sorry I am a bit of a noob!
I know i can buy a denon 260L cheap but i would like digital/DAB pls - i dont mind a full size unit -
PS it doesn't have to be REGA :):):):)
Black Gyro SE / SME IV / Primare I32  R32 / AT33 PTG II / ATC SCM11
John Duncan's picture
Last seen: 2 months 2 weeks ago
RE: DAB Tuner? PP some advice please
I'd buy a streamer rather than a DAB radio - Sonos connect will give you all the world's radio and more, or if you want more hifi-esque equipment, I'd consider Denon, Marantz, Pioneer, Cambridge Audio, Naim. The latter options may give you more access to 'catch up' services like podcasts etc, but I haven't tended to use them.
Moderator: john.duncan.whf at gmail dot com
System burgeoning
i do have an ATV3 going into my DAC, might have to connect it to my telly - do you know if that provides any radio? Listen at me I am being lazy!
I could possibly connect my Sky box to my DAC?
plastic penguin's picture
Last seen: 13 hours 55 min ago
I would say streamer...
The only digital radio I have is Freeview via the TV and Sky box. Then again the SQ of the SB channels are good to iffy.
Leema Pulse; Arcam CD73; PMC TB2i; Pro-ject Xpression with a ClearAudio cart; Denon TU260 MKII
You could do either, but from my recollection of ATV, Apple have some major omissions in their radio catalogue (like, say, the BBC); not sure if it has iPlayer built in? I don't know about Sky's radio catalogue at all but if it's anything like Virgin's it's limited to the usual UK suspects and doesn't offer any world radio.
System burgeoning
The ONLY reason I've considered another tuner is purely for FM...
In your circumstance I'd certainly look at something like Marantz (I know its discontinued) that can act as a conventional tuner and streamer.
ok cheers - i might just get a little portable one - i only want it to listen to local footbal radio 2 & 5 - not bothered about it going through my hifi, think it will be the cheapest option
richardw42's picture
Last seen: 2 weeks 12 hours ago
Have you got a smartphone / tablet ?
if so you could get an app like Tunein and airplay to your ATV3.
BIGBERNARDBRESSLAW's picture
Last seen: 9 months 5 days ago
I'm not 100% certain, but you should be able to pick up a lot of stations through your pc/mac/laptop Steve.
Panasonic TX-P50GT50 / Yamaha RX-A2020 / Panasonic DMP-BDT110 / Dali Zensor 3 / Dali Zensor Vokal / Mordaunt Short MS20i Pearl Edition / Cambridge Audio Minx 11 / Tannoy TS2.10 / Roksan Radius 5.2 / Ortofon Super OM 20
Just did a quich check of ATV3. BBC R1-5 are all there. Not arranged particularly well. And no search ?
http://www.listenlive.eu/uk.html
Should be any station you need here Steve.
Of course, stupid of me - that's exactly what you should do Smile
System burgeoning
i should have have said as long as it's Apple Smile
drummerman's picture
Last seen: 3 days 7 hours ago
Kinda related, I just received my cyrus tuner.
Absolutely lovely sound, that is without a roof aerial.
regards
There are a couple of paid-for apps in the play android store that implement Airplay, but I haven't tried them as Bluetooth works for me.
System burgeoning
yep will have a look - yes got iphone etc - try streaming radio 2 on my iphone via airplay to my atv3 then into my dac it didnt work, i will have a look at tune-in
thanks
Pages
Log in to post comments
