Cyrus Amp, what speakers ? HELP
13 replies [Last post]
SeanRussell
SeanRussell's picture
I have just bought a Cyrus 3 amp and now need some speakers. Here is where the problems starts, I only have a limted budget but it seems that there arnt any budget speakers that work with Cyrus due to the enthusiatsic treble.
I will send my music through a DAC and into the amp and I mainly listen to folky and Indie music. Please give me some speakers to have a look out for they can be in any shape or form, brand new or second hand aslong as there budget speakers and dont sound too bright with the cyrus.
Any input or ideas are welcome
Thankyou
__________________
HIFI- Amp Cyrus 3, Speakers B&W DM110, Source PC lossless files
Need- Beresford TC-7520, Acoustic energy 109
Crossie
Crossie's picture
RE: Cyrus Amp, what speakers ? HELP
it would help if you could set a maximum price. Do you want stand mounted or florstanding speakers? What size is your room?
Cheers  beauty, eh
__________________
Toshiba Netbook J River, Cyrus Pre XPdQX with PSX-R, 4 x Cyrus Mono X's, Wilmslow Phoenix with Bass Extenders.
SeanRussell
Cheers  beauty, eh
Realistically my maximum budget is around £250 and the room is 13ft x 12ft speakers along the longest side and. I will consider floor standers and standmounters, Thanks for your reply
__________________
d_a_n1979
d_a_n1979's picture
These would work well; theyre an easy drive and great sounding too:
http://www.ebay.co.uk/itm/350700140463?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
They'll help to keep the Cyrus top-end in check
SeanRussell
Thats great thanks, do all Acoustic Energy speakers gel with the Cyrus, I have been looking at the Neo 1 V2 ?
__________________
kev g
kev g's picture
just a thought - another alternative could be these floorstanders.... http://www.ebay.co.uk/itm/Tannoy-revolution-R2-/121061678100?pt=UK_Audio... Have never heard Tannoy & Cyrus together but I can see no reason that the sound would be harsh.
__________________
Hi-Fi - Arcam A75+ amp, Marantz CD6000OSE KI Sig, Sony ST-SE700 Tuner*, Tannoy R2 speakers
Cables - Van Den Hul The First Ultimate*, Van Den Hul The Bay, Chord Odyssey 2*, Audusa Eupen mains cable, Tacima CS929 mains block.
A/V Sony 32EX503, Sony BDV-E370*, Humax Foxsat HDR*
* Second Hand
d_a_n1979
d_a_n1979's picture
I've found they worked really well (all be it, it was a Cyrus 8VS2 I had). Heard it with the Aelite 2's, AESprit 2's, AE109's and the Neo 3 V2's and they all worked really well, in particular the AE109's - still a fave of mine as they were my very first speakers alongside an Arcam Alpha 6 amp and 6 CD player)!
The soft dome tweeter just seems to gel well with the Cyrus sound and it calms that slight brightness/harshness that can be there at times but then again this does depend on the quality of sound being fed to the amp etc...
SeanRussell
Thankyou both very much. They both look like they could be just whats needed to tame the Cyrus, will apple lossless files run through a DAC be okay sound quality wise ?
__________________
kev g
kev g's picture
If possible take along your amp to a dealer & audition the AE`s
Another floorstander alternative - Tannoy V4
__________________
* Second Hand
SeanRussell
kev g wrote:
If possible take along your amp to a dealer & audition the AE`s Another floorstander alternative - Tannoy V4
You have just saved me a post, as I've heard the Tannoy V4's have quite a sweet treble and they received a glistening review from WHF. Ill put them on my fast becoming long "short list"
__________________
d_a_n1979
d_a_n1979's picture
Yup Smile
All my music is via iTunes, AirPlay and an ATV2 for my living room system... No issues with sound quality at all Laughing out loud
SeanRussell
Am I being naive or would the wharfedale 10.1/10.3 be a okay match aswell ?
__________________
d_a_n1979
d_a_n1979's picture
They'd be fine but you can do better!
The AE Neo 3 V2's are available on eBay for c£250 IIRC.
The AE speakers are much better overall that the Wharfedale's IMO. The Wharfedale's are good speakers but they are budget speakers; the Cyrus deserves better I feel
SeanRussell
I had a hunch that would be the case, I think im going to organise an audition with the Neo 1 V2's and the Neo 3 V2s and the others that have been recommended.
Thankyou once again
__________________
