9 posts / 0 new
Last post
admin's picture
Last seen: 6 hours 3 min ago
Cyrus 8vs2
Just received my used Cyrus 8Vs2 int. amp. Its replacing a Marantz pm 66ki. Bit embarressed asking this question - here goes. My Marantz had plugs to connect speakers. The speaker outputs on the back of the Cyrus are very different and in no way would accomodate the plugs i currently have, even with a hammer lol. Stupid I know but please help. While im makin a full of myself. The chord interconnects cd to amp i have are red and black? how do i know what is positive /negative in this respect and do both interconnects go from amp to cd. My cd is an old 63ki sig marantz. Im 77 and used to analogue, any help appreciated.
eternaloptimist's picture
Last seen: 1 month 3 weeks ago
Re: Cyrus 8vs2
Hi runforfree,
You need to use BFA speaker plugs which should have come with the amp (I used to have an 8vs2).
They look like this; http://www.bartlettshifi.com/product_detail.asp?sku=1293
They don't have to be Cyrus brand.
Cheers,
(Cyrus CD 6SE) / MacMini (HQPlayer NAA / JRiver MC22) + PC (Roon + HQPlayer) + Synology NAS -> T&A DAC 8 DSD -> Cyrus Mono x200 Signatures -> Audiovector Si3 Avantgarde Arretes
Anonymous's picture
Re: Cyrus 8vs2
When you get up and running, you'll find its a great amp.  What speakers are you running it with?
Regarding the interconnects.  Yes, both should go from player to amp.  The outputs on your player should be marked Right and Left, as should the inputs on your amp.  All you need to remember is Red = Right, and you'll be fine.  The other interconnect will either be Black or White, and should go to the left channel.
The same rule applies for your speaker cables, and the BFA plugs you get will be red and black.  They should be connected to the corresponding speaker wires in the cable (if you don't feel confident making up cables, then get the shop where you buy the plugs to attach them for you).
Good luck and enjoy your lovely new amp.
Merry Christmas,
Shuggie
Gusboll's picture
Last seen: 1 year 3 weeks ago
Re: Cyrus 8vs2
If you don't mind saying, how much did you get it for? I think it's a cracking amp.
Currently listening to: Gang of Four
Anonymous's picture
Re: Cyrus 8vs2
Hi D,
Much appreciate your advice, i got quite a shock when I saw the speaker inputs on the amp. I understand where to go now.
Thanks again.
Will.
Anonymous's picture
Re: Cyrus 8vs2
Hi Shuggie,
Thanks for your advice, that has indeed set me straight. Im going to start off with a pair of Epos m5i`s - if I like the sound then I wont change the spreakers.
Cheers and a Merry Christmas to you,
Will.
Anonymous's picture
Re: Cyrus 8vs2
Hi Gusball,
Im hoping it will be a £380 silver bargain - bought from an auction site with a recent service and 3 month warranty, fingers crossed.
Will.
datay's picture
Last seen: 2 years 7 months ago
Re: Cyrus 8vs2
You might want to check the warranty out - according to the Cyrus manuals the warranty is non-transferable, i.e. covers original owner only. I know as I didn't check this until after I'd bought a used piece of Cyrus gear (no problems with it, mind).
Anonymous's picture
Re: Cyrus 8vs2
Will do, thanks for that . Hoping to avoid problems for a little while.
Reagrds
will
Log in to post comments
