7 posts / 0 new
Last post
PLuKE's picture
Last seen: 3 months 6 days ago
Corner speaker, more bassy?
Hi
Was playing around tonight with my speakers, so one of my speakers is in a corner, around 20" away.
This speaker sounds more "bassy"  compared to the other.
Would the wall be affecting the bass?
Picture, http://img9.imageshack.us/i/imagetnft.jpg/
Speakers are B&W 685 so forward firing ports and a NAD 320BEE amp.
Luke
Baldrick1's picture
Last seen: 2 years 6 months ago
RE: Corner speaker, more bassy?
Yup, in general if youstick a speaker in a corner it will sound more bassy...but by how much will depend on the speaker itself and how the designer intended for it to be placed.  There some speakers that are in facat designed to be placed in corners and do not sound right if given more room to breated then they were designed to use.
JohnKK's picture
Last seen: 1 year 10 months ago
I would say that some booming could come from side wall but it is more likely that back wall is making this boom.
I had 685 on tv cabinet and had big issues with booming; few sets of speakers later I learnt that min 30cm from back wall is mandatory (and speakers stands if you want full potential out of speakers).
How close to back wall do you have them?
ID.
ID.'s picture
Last seen: 1 week 5 days ago
Corners will result in more, and looser, bass. Despite the front port, the 685s like quite a bit of space (e.g. 30cm from the rear wall, as mentioned) and some solid stands, otherwise they are prone to booming.
PLuKE's picture
They used to be on stands, but space doesn't allow at the moment. They are some polystyrene to help. They are only 2-3" at best away from the rear wall and the walls are paper thin on both rear and side wall.
It sounded like the amp/speaker wasn't working correctly when I was listening to the speaker next to the wall and the other speaker which is "free" it had more kick to the bass, but goes this is due to the wall?
Many thanks for people's input!!
Luke
RobinKidderminster's picture
Last seen: 2 months 3 weeks ago
U could try a rockwool board behind the speakers. See my sig for the idea. I can't really guarantee the effects but to try for just a few quid may be worth a try?
Yamaha V2065. MS Mezzo 5.1 Panasonic 42. Sony BD. Garrard 86SB. WD Live TV. SkyHD.
http://www.whathifi.com/forum/home-cinema/lounge-hc-signature-update-bass-traps
PLuKE's picture
I used to have some canvas pictures with the insides having foam, put them behind the speakers. But that was at my parents in my bedroom, now I have my own place, need to make it look alittle more subtle.
Luke
Log in to post comments
