Considering ATC SCM 7
12 replies [Last post]
moon
moon's picture
Luckilly I'm in a position now to consider this speaker. Cool I'm  not getting rid  of my amp because frankly its really well made and has the connections I require. So, will it give the Scm7's enough ummph.?
I listen to a lot of electronic music but also some very heavy guitar/ electronic based music and some Jazz. The closed box design appeals.
Also not sure I've ever seen these available for audition in shop round my way.
__________________
David@FrankHarvey
David@FrankHarvey's picture
RE: Considering ATC SCM 7
I don't have any experience of your amplifier, so others may be able to help there, but if youve heard sealed cabinet speakers before and they appeal, the SCM7 should be your first port of call. They may not sound quite as lively as your Tannoys, but you should find them far more refined and natural sounding.
__________________
David @Frank Harvey Hi-Fi, Coventry
Mitsubishi HC7000 / Oppo BDP103 / Audiolab 8200AP / Rotel RMB1575 / kick ass speaker system
OneBoxSystem
OneBoxSystem's picture
It's Rick time...Tongue out
ebentjerodt
ebentjerodt's picture
Hi Moon,
I have not hear the SCM 7 but I have heard many times the SMC 11, 19 and 20 with several amp (ss and Tube) and they sound just great!
so  the SCM 7 should be a great option!
kr
Eduardo
__________________
OLIVE 06 HD/ CHORD QDB76HDSD DAC / CHORD PRIMA PREAMP / ATC SCM50 ASLT / MERIDIAN i80
David@FrankHarvey
Sorry, was mine too understated?  excellent!
__________________
plastic penguin
plastic penguin's picture
Oddly, he hasn't been around much since WHFI announced the speaker awards. twisted
__________________
Leema Pulse MKII-S; Naim CD5i MKII; Denon TU-260L MKII; MA RS6 speakers; Pro-ject Xpression 1; loads of different cables...
Formerly known as plastic penguin
moon
moon's picture
Thanks for the response, It looks as if they will be perfect for my room. Wether they are £515 pounds better will be the question. By the way has there been a recent price hike for these?
__________________
David@FrankHarvey
Not since April 2011.
__________________
BenLaw
BenLaw's picture
Where are you based moon? See if we can find you a dealer to have a demo at?
__________________
HiFi   /   A/V   /   Bedroom
MUSICRAFT
MUSICRAFT's picture
Hi moon
As long as you're not after constant disco like listening levels then i would say that the Azur 351A has got sufficient quality and quantity of power to be paired with SCM7 monitors.
Fwiw, i also got clients happily using Cambridge Audio amplification with ATC passive monitors.
All the best
Rick @ Musicraft
__________________
Musicraft (Derby), Specialist Hi-Fi/AV & Multimedia Dealer
good accurate audio monitoring and good sound reproduction to all Smile
moon
moon's picture
Hi Ben, thanks for the reply. I live down on the south coast. I'm also going to give some other mini monitors an audition like the RS1 and the B & W CM1. Smile
__________________
moon
moon's picture
MUSICRAFT wrote:
Hi moon
All the best
Rick @ Musicraft
Thanks for the info Rick.
All the best
Moon
__________________
hoopsontoast
hoopsontoast's picture
I loved the SCM7's, my favourite speaker under £1k that you can buy new excellent!
Also have a look at the SCM10, same mid bass in a larger cabinet and a little more refined presentation (Better Tweeter IMO)
I prefer the SCM7 to the SCM11 FWIW, they have better integration between the treble and mid bass at the expense of a little bass depth (not as much as you would think) unless you have a big room.
Personally I would have thought something like the CA 840A would be a better match if you were to stay with CA, but I used the SCM10's with a T-Amp in a small room and the SCM7's with a 50w Teac/Thule Amp.
IME they like an amp with decent drive, if not outright power.
__________________
Sony DVP-S9000ES | DIY SET / Eagle SA100 | DIY Speakers / Eclipse TD-508 / Keesonic Kolt
