20 posts / 0 new
Last post
Covenanter's picture
Last seen: 1 week 3 days ago
Combine or separate
I'm going to refurbish my apartment, new flooring, heating, etc and one of the things I'm thinking about is what to do with my AV sound system.  Should I try to combine it with my hifi using my R700s or should I keep it separate.  I listen to music maybe 2 to 3 hours a day on average and use the AV maybe once a week to watch/listen to a DVD.
If combine what would you recommend?  If separate (maybe a question for a different forum) what would you recommend?
Chris
Marantz PM8005 / SA8005 / KEF R700s / AKG K702
KidKomet's picture
Last seen: 1 year 11 months ago
RE: Combine or separate
My personal preference is to keep my HiFi and my AV systems separate. 2 different systems for 2 different purposes.
hifikrazy's picture
You can actually combine them like what I do without any downsides.  I'm using the same pair of speakers for music listening and as main front speakers for AV.
For music listening:  CD player connected to preamp connected to power amp connected to speakers
For AV:  Media player connected to AV amp connected to preamp (via the AV amp's preout) connected to power amp connected to speakers. Center channel (preferably the Kef R600c or R200c), surround speakers and subwoofer are connected to AV amp directly.
I think you can make use of your PM8005's Power Amp Direct function for connecting to your AV amp's preout.
Glacialpath's picture
Last seen: 4 months 3 weeks ago
I agree with hifikrazy.
Combine them but keep music and AV seperate.
Hi-Fi: Campridge audio D500 SE, DACMagic 1, C500, P500.. Monitor Audio BR1 speakers.
H-T: Pioneer; Kuro LX5090, BDP LX71, SC LX73. CA P500. SKY+HD. Rel Q50. Mordaunt Short Avant.
CnoEvil's picture
Last seen: 3 days 5 hours ago
Good advice above.
The best way is to keep them totally separate, but this takes up two rooms and is more expensive.
A very reasonable compromise (as has been suggested), is to combine but keep separate, by using the Pre-Outs of the AV amp. It greatly helps (but not essential) if the 2 channel amp has an HT Bypass.
"We should no more let numbers define audio quality than we should let chemical analysis be the arbiter of fine wines."  Nelson Pass
Vladimir's picture
Last seen: 9 months 13 hours ago
Can someone explain what is the downside for using AVR in stereo mode vs stereo 2 channel amplifier.
Thanks.
Hi-FiOutlaw's picture
Last seen: 2 weeks 6 hours ago
If listening space is going to be shared between Stereo and AV i think a combine solution it will reduce cables and speakers, therefor a simpler solution. your KEF R700 will be a hell of front channels, just add the R central and matching rears (or existing ones) and off you go! Dirol :cheers:
Rega RP6/Goldring Elite MC>Clearaudio Basic Plus
Synology NAS>Auralic Vega>Pathos Classic One MKIII>Dynaudio X12
matt49's picture
Last seen: 2 weeks 1 day ago
Thanks.
OK, I'll take the bait.
It limits your choice of amplification.
:cheers:
Matt
nima's picture
Last seen: 1 year 2 months ago
Thanks.
It sounds rubbish.
nima's picture
2 channel amp with HT Bypass is a way to go.
How often do you actually watch films in multi-channel setting? If not that many, stereo could be more than adequate.
CnoEvil's picture
....especially if you add a Sub.
abacus's picture
Last seen: 5 hours 28 min ago
If you can acoustically treat your room (Or the acoustics are already good) then the simpler amplifier path is the way to go, if however you can’t, (Always difficult in a domestic environment) then you can usually get a much more accurate sound by using the room correction facilities of an AV Receiver. (This does mean that everything has to go through the AV Receiver though) Swings & Roundabouts I’m afraid.
Note; you can also get professional  room correction hardware (Pop down to your local music store to see what’s available) which will be vastly superior to any that are fitted to Home AV/Hi Fi equipment, so is another option if you just want to use the amplifier path and can’t use acoustic treatment.
Hope this helps
Bill
Esra's picture
Last seen: 3 months 3 days ago
http://www.thomann.de/gb/behringer_deq2496_ultracurve_pro.htm
a nice and affordable device that helps a lot if you can´t treat your room.I have used myself and sold as I don´t need it any more.
the record spot's picture
Last seen: 1 year 9 months ago
nima wrote:
Thanks.
It sounds rubbish.
Yes, well, that's the trouble with absolutes isn't it?  They just don't stack up all of the time.
No point asking me Chris.  I ditched my integrated amp ages ago and haven't looked back.  The Onkyo is an incredibly strong outfielder, drives my current speakers (Pioneer S71-B) with ease and would only get replaced by another AV amp.  Wouldn't dream of going back.
richardw42's picture
Last seen: 1 week 2 days ago
This forum hasn't moved on at all.
DocG's picture
Hence Cno's baseline: "Everything has been said before, but since nobody listens we have to keep going back and beginning all over again."   by André Gide... Smile
M50 - D120 - LS50
Pages
Log in to post comments
