9 posts / 0 new
Last post
admin's picture
Last seen: 1 week 1 day ago
co-axial or interconnect
I am buying a new cd player for my av receiver (denon 3805) and was wondering which is the better audio cable interconnect or coaxial. Sorry if this is a daft question but i am only just started to take audio seriously.
thanks
nads's picture
Last seen: 6 months 1 week ago
Re: co-axial or interconnect
IMHO it depends on which has the best built in DAC.
Andrew Everard's picture
Last seen: 3 years 6 months ago
Which in turn depends on what your CD player is going to be...
Anonymous's picture
Likely to be Rega Apollo auditioning this weekend
John Duncan's picture
Last seen: 2 months 2 weeks ago
Then the DAC will be better in the Apollo (or certainly should be) and you should use stereo interconnects.
Moderator: john.duncan.whf at gmail dot com
System burgeoning
Though (IMO) the Denon will probably not get the best out of the Apollo either way - are you sure you need to spend as much if the amp can't show it in it's best light?  I am yet to be convinced of the 'source first' theory.
Cue flames.
System burgeoning
Anonymous's picture
I am replacing my denon later this year with either the pioneer LX70/ Onkyo 875 or another which may make a difference
Anonymous's picture
Snap.
Snap.
Gasp.  A fellow heretic?
System burgeoning
Log in to post comments
