60 posts / 0 new
Last post
Neuphonix's picture
Classe amplification
Hi all,
I have an opportunity to do a home demo of a Classe CA401 power amplifier.
Was wondering if anyone had any experiences with this model or Classe amplifiers in general that they could share.
Can't find a whole lot about this particular model, what there is seems to be generally positive.
It is A-B but seems to be strongly bias toward A (read somewhere that it uses some sort of sliding bias(?) which allows it to provide around 85w of class A before switching)
I'm just interested in hearing how a more powerful amplifier compares to the AMP35P with my new Kefs.
Anyone have anything to share? Dave? Cno?
CnoEvil's picture
Last seen: 2 weeks 6 days ago
RE: Classe amplification
Nothing to share but a guess, I'm afraid.
I would expect the Classe to exert more control over the speakers, but while smooth, it might not quite have that addictive quality that only comes from true Class A. I also suspect that the bass would be a little tighter but wouldn't sound as deep.
I have generally found that high bias amps never sound quite as good as the real thing. Remember that 85W of Class A would get to 85 Deg C, and have a weight heading towards 85 kg.
Classe is certainly one of the brands that I think would work very well with the 205/2s.....along with Electrcompaniet (AW250), Plinius (SA 103), McIntosh (MC275), Audio Analogue (Class SE / Duescento)  and VTL (ST-150). David and Frogfish like Bryston.
IMO and for my taste, Refs like a high current (and high power if poss) amp with a hint of sweetness or they can sound a little analytical
I have heard a lot of amplification, and there is very little I would swop the 35i for. If you are tempted, make sure you have a very long listen before making a decision...probably a week at home.
I suspect this might be a difficult, but intriguing decision...... :?
"We should no more let numbers define audio quality than we should let chemical analysis be the arbiter of fine wines."  Nelson Pass
Macspur's picture
Last seen: 1 week 5 days ago
Hi there,
Must say I'm a bit surprised you're even considering changing the beloved MF!
I understand Classe is supposed to be a top brand and particularly well matched with B&W, but whether it's better than the MF power amp, I'm not sure... like Cno says all you can do is have a good home demo and hear for yourself.
Good luck... looking forward to another interesting experience of yours.
Smile
Mac
www.macsmusic.blogbubble.net
Electrocompaniet EMC1UP, Audiolab M-DAC+, Sonos Connect, Accuphase E470, Harbeth SHL5 Plus, Auditorium 23 SC, HiFi Racks Podium Reference rack, matching LS stands.
Neuphonix's picture
HI mate,
intriguing indeed.
http://www.classeaudio.com/discontinued/specs/ca401.htm
It is quite a big amp at 60kg & draws much the same in standby as the 35i @ 350w
Not expecting a night and day shift, just interested to hear if a more powerful amp does have any noticeable effect. I guess at 90dB the 205/2 are not the most demanding load & at my normal listening volumes I'm not sure I need the extra power. So more an experiment for the sake of experiementation, I think they'll let me have it at home for a week, I am going to push for two. There are a few other questions about change over cost / age & condition of the unit (haven't seen it yet) / reason for sale to be nutted out. They also sell Pass Lab which I always seem to read about very favourably. No trade in deals there though so probably a bit beyond my budget at the moment. Have you heard any Pass gear? Do you have any thoughts about the mixing of brands ie MF pre-amp with another power? Why do you mention that you think there will be less bass? Just a strength of the 35i, or another technical reason?
I found this discussion which was interesting, few mentions of use with Kefs:
http://www.audiokarma.org/forums/archive/index.php/t-243860.html
With this one particular quote about the adaptive biasing:
This amp runs considerably into class A to a point and then runs A/B to be more efficient into higher demands. I think I remember that it is class A to 100 watts then class A/B above that.
I decided to go straight to the grapevine to put an end to the speculation, so I contacted Classe technical support. According to Robert Adam, the CA-300 and CA-400 have adaptive biasing. This probably explains their convoluted 24 hour bias adjustment procedure. Bias is kept low at idle to reduce heat, and increases under the load as output increases. Both models run class A up to 20% of rated power before running in class B. That means 60W and 80W respectively
CnoEvil's picture
You don't need the extra power, but it will be very interesting to see what effect it has, as the Refs thrive on it.
I have never heard a Pass Labs amp, but they have a great reputation.
It's only a hunch, but the MF AMS power amps do fantastic bass, and I think I read somewhere (but could easily be wrong) that Classe, while having very good bass, don't have the best bass out there.
I remain sceptical about 80W Pure Class A.....The AMS50 weighs 60kg, gives 50 Watts into 8 Ohms, and has a power consumption of 600W (and the 35i was measured drawing over 400W).
Neuphonix's picture
@ Mac
thanks Mac, I'm not REALLY considering all that seriously, just this dealer is a very bad man!!! He keeps calling me to chat about new things that have been dropped off to the store  :doh: Can't see it being a night and day difference such as I experienced with the speaker change over.
@ Cno
You're right I have read in a few thread that bass isn't one of the Classe strengths, but then this seems to be mostly when being compared to some pretty high end amps. I really can't see it being a weakness relatively speaking.
I share your skepticism about the pure class A definition. Also the age of the amp makes me pause, any repairs could be costly.
Any reservations about mixing different brands of pre / power?
CnoEvil's picture
It's not an area I'm strong on, but I think you need to check if output / input impedances would be compatible.....the dealer or manufacturers should be able to confirm.
Sound-wise, I don't see a problem.....but it's a case of suck it and see.
matt49's picture
Last seen: 2 months 3 weeks ago
I heard the Pass Labs INT-30A. A really fine amplifier, very similar in sound to the MF AMS35i, I think. I auditioned it against the Luxman L-550 AII and preferred the Pass Labs by a considerable margin.
:cheers:
Matt
CnoEvil's picture
:cheers:
Matt
I remember, now you mention it.
A Devialet might also be a good match with Refs.  :shifty:
Neuphonix's picture
[/quote]
[/quote]
Don't go there  :shame:
Thanks for the input Matt, much appreciated.  Smile
WishTree's picture
Last seen: 1 year 6 months ago
I had Classe CA-2100 driving KEF Reference 201/2 at home for a short period. The Classe was with me for long time, so I was familiar how it sounds. Where as KEF was with me for less than week (used product - so all run in etc).
IMO, the combination was one of the best that I owned and there is a great amount of lightness to the sound. I will not go in detail about what I remembered but all in all it's a good combination.
Coming back to what I think, I would go with what Cno says. I used have Pathos Inpol2 and that was the best amp ever for me (though I did not hear AMS 35i). Pure Class A amps have some kind of sweetness and in Pathos it becomes slightly more evident but some how it is never overly done. And, KEF reference, really need that.
If I have to put a combo blindly based on what I heard, I would put Pathos and KEF Reference together. When it comes to Classe amplification, they are almost neutral but again IMO, they go better with 800 series of B&W. For lack of any other better way of putting it, the slight warmth of 800 series goes well with the superb control and 'leanness' of Classe. I am saying all this based on CA 2100 and not the bigger counterparts from Classe but this gives an idea.
I am reading a bit on the amp offered to you, and it looks like it is completely in a different league. If the price is something that you can live with and there is enough support for Classe from your dealer (given that this is an old'ish model), then I think it is worth a home demo. But given your 35p, I have a feeling it might be purely academic activity !
| Devialet Silver Phantom X 2 | Dialogue |
MUSICRAFT's picture
Last seen: 1 day 11 hours ago
Hi Neuphonix
I owned a CA-401 and used the CA-401 with many speakers including KEF Reference. I now use a Krell FPB600 which is an amp around five years older then the CA-401.
I'll recommend that you should carry on using the AMS-35P. If you want to try a different power amplifier then Krell FPB200 or a FPB300 are also worth bearing in mind.
All the best
Rick @ Musicraft
Musicraft (Derby) - Specialist Hi-Fi/AV Dealer
My system - Naim Core > Hegel HD30 > Hegel P30 > JL Audio CR-1 > ATC SCM100ASL Professional Monitors > 2 x JL Audio E-112
davidf's picture
Last seen: 2 days 1 hour ago
As well as the Bryston 4Bsst2" I'd also recommend trying the Chord SPM1050, or even the SPM1200 (if within reach). They seem to match the 205/2's just as well as the Bryston, but do have a bit of a different sound - they certainly seem to reach a little deeper than the Bryston
the little audio company
audioquest / audio technica / amphion / bluesound / chord co / cornered audio / cyrus / elipson / golden ear / innuos / jbl / kef / moon / ophidian / primare / revel / svs
MUSICRAFT's picture
Hi Neuphonix
I see that you also use JL Audio's Fathom f112 and f110 subwoofers. Very nice  Dirol  Out of interest what configuration do you use the Fathom f112 and f110 subwoofers in please?
All the best
Rick @ Musicraft
Neuphonix's picture
Thanks everyone for the replies, really appreciate the input.
Seems the general consensus is to stay with the 35P.
I'm only really considering the Classe because it is a trade in unit with a dealer who will let me trade for it, the change over cost would be fairly reasonable. But TBH it would have to be pretty special for me to part ways with the 35P.
Few too many factors going against it, age of the unit & spending more money not the least of them. But they will let me demo so what the heck, got nothing to lose.
I'll let you all know how things progress.
David & Rick do you have any reservations in regards to mixing brands of pre-amp / power amp?
Do you think that the extra power offered by the Classe will have any benefit for the 205/2?
@ Rick regarding the Fathoms. I was using them in my hifi set-up through a Bryston 10B sub active cross-over with my previous speakers, Focal Diablos. Since making the swap over to the 205/2 I haven't felt the need. Did try running them via the RCA outs on the pre-amp but I wasn't happy with the way they worked. Might try fiddling again, but feel at the moment the Kefs give me plenty of bottom end.
I'm definitely no expert & my room probably has a few issues, but I tended to find that using subs was a bit hit & miss. Sounded fantastic on some tracks & not so great on others. I also think that trying to have them set-up for Hifi & HT complicated the matter further.
So at the moment they are just being used for HT, for which they perform admirably, two subs is a bit ridiculous, but hey!
I originally wanted to buy the velodyne DD+ subs, but found the JL Audios to be much better VFM. The ability to have been able to set the DD+ up on different pre-sets (hifi or HT) which I could swap between via remote would have been very useful.
Do you use a sub? If so what sort?
CnoEvil's picture
- I think experimentation is never wasted, as the only real way to get more knowledge, is to try stuff. Other people's descriptions can be helpful, but are no substitute.
- Remember, any amp that gets very hot is likely to take a greater toll on its electrical components, so age could be an issue.
- Refs love power/current, but you have to like how it makes them sound. I didn't like them on the end of Linn Klimax gear, nor surprisingly with the Rega Osiris. The 35P is very capable, and considerably more potent than the 35i.
- Mixing brands is quite normal eg. A Tube Pre of one brand (like Croft) with a SS Power.
- I have always preferred the seamless presentation of a well designed speaker, that has enough scale for my needs, than trying to integrate a sub.
Pages
Log in to post comments
