8 posts / 0 new
Last post
jim.123's picture
Celestion need replacement tweeters
I have some old celestion f20 speakers which were great until the tweeters went. Does anyone know what I could replace them with and where I could look online? Celestion don't make them anymore and I don't really care about them being exact copies; I just need some that fit the speakers and work. I'm not even sure what to look for. Is it size primarily, and resistance?
thanks in advance,
jim
chebby's picture
Last seen: 11 hours 58 min ago
RE: Celestion need replacement tweeters
Buy the cheapest pair of used (working) Celestion F10s you can find on ebay and use their tweeters.
It will probably be cheaper than a replacement pair. (Even assuming you could find any.)
iPad Mini 3 • iPhone 6 • B&W P3 • Mac Mini • Apple TV3 • Quad Vena • Pro-ject Tuner Box S • Audio-Note AX-Two
matthewpiano's picture
Last seen: 1 month 10 hours ago
Agree with Chebby.
If not, contact Wilmslow Audio for advice.  They will be able to recommend a replacement tweeter of similar spec.
Rega RP3/Elys2/TT PSU- Denon DCD720ae - Pioneer A400  -  Wharfedale Diamond 220 - Atlas Equator 2.0 - Beyer DT-770PRO - Mission stands
Coll's picture
Last seen: 1 week 5 days ago
You could also try Falcon Acoustics look them up on the net they have a huge range of old drivers
Richard Allen's picture
Last seen: 2 years 1 month ago
jim.123 wrote:
thanks in advance,
jim
Hi Jim. Pound to a pinch they're HF1300s. Wilmslow Audio. 01455 286603. Ask for Terry or Neil.
chebby's picture
Richard Allen wrote:
jim.123 wrote:
thanks in advance,
jim
Were the HF1300s 19mm Titanium dome tweeters? (That's what the OP's Celestion F20s have.)
jim.123's picture
Many thanks you lot. Will see what I can find!
Jim
Jim
Also, try Celestion Consumer Division on 01622 687442.
Log in to post comments
