6 posts / 0 new
Last post
Viking's picture
Last seen: 2 years 2 hours ago
CD player suggestions please
Hi, could anyone suggest a CD player which will partner well with a Nac CB356BEE and a pair of B&W 683's. I'm using an older Rotel RCD 930AX at the moment and the sound is pretty good, though it's starting to have a few minor problems at the moment. If I was going for a better quality player, how much will I need to spend and on which CD player. I mostly listen to heavy music such as Soulfly, Trivium, Megadeth, Metallica etc. Thanks for any advise.
bigfish786's picture
Last seen: 1 week 4 days ago
RE: CD player suggestions please
hi, i have the same taste in music as yourself, i recently bought a used rega apollo cd player, which i can highly reccommend.
you can get them for around 200, but i have seen them go for much less on ebay / gumtree
Marantz TT15S1. Leema Pulse. Moon Equinox. Focal Chorus 826V. Nagaoka TS12. Clearaudio Virtuoso. Musical Fidelity MF100. SONY KD65XD7505 4K TV.
KidKomet's picture
Last seen: 2 years 1 month ago
What kind of budget do you have? And have you considered a CD player as a transport in to a higher quality DAC?
magnus78's picture
Last seen: 2 years 2 months ago
can consider the Marantz CD6005. I bought it yesterday and played with some cds, very muscial and detailed. Very well built as well. And yes a onboard dac as a bonus.
Viking's picture
Thanks for your suggestion with the rega apollo. I took a look at it, but a top loader is not for me. I think the budget will be no more than 500 pounds so I'm not sure if the investement is going to be that much better than my old Rotel.
Thanks again.
Viking's picture
Hi, my budget would be no more than 500 pounds, but am interrested in the DAC idea. What would yoy suggest and what is the advantage above an ordinary CD player.
Thanks for your help.
Log in to post comments
