Can one speaker be used for two seperate sytems.
4 replies [Last post]
jk1988
jk1988's picture
Can one set of speakers be used on two different amplifiers one being an av amp the other a stereo amp as long as the speakers are bi wire capable. Or do I need two do somenthing else.
__________________
T.V Samsung 50" series 5 Plasma. Onkyo TR-606 Av Reciever. Denon BD-1611. Virging Tivo. PS3.
Tannoy F3 fronts, Tannoy FC centre. Qacoutics 2020 rears.
Marantz PM6004. Marantz CD6004. Kef Q300.
Andrew Everard
Andrew Everard's picture
Online
RE: Can one speaker be used for two seperate sytems.
You need a speaker switch between the speakers and the amps: if you connect both amps to the speakers using the biwire terminals you risk damaging the speakers and/or one or both amps.
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
John Duncan
John Duncan's picture
Online
What he said, mostly, but can I just be clear on what you're trying to do? Why do you want to connect two amps to the speakers and what are the amps?
__________________
CA StreamMagic 6  |  CA 751BD  |  CA 651A  |  PMC DB1i
Moderator. mail: john.duncan.whf at the mail of g dot com
Neuphonix
Neuphonix's picture
Have the same situation at home. I use the Beresford TC-7220 unit that many on here have recommended.
It works perfectly, build quality is great & the service was teriffic also. Can recommend it.
http://www.beresford.me/products/TC-7220.html
__________________
MF AMS-Primo / MF AMS-35P / Linn Akurate DS / Focal Utopia Diablos / Krix Epicentrix / Focal Dome 2 / JL Audio Fathom F110 / JL Audio Fathom F112 / Bryston 10B-Sub / Yamaha RX-Z7 / Oppo Nuforce BDP-93 / PS3 / QNAP TS-219P Turbo NAS
jk1988
jk1988's picture
Thankyou for your replies it sounds as if the beresford will work as I am looking at buying some kef speakers to use as surrounds  but I also want to use them on my marantz 6004 set up,
__________________
