can digital coax / optical outputs be used at the same time as xlr outputs ???????????
2 replies [Last post]
toyota man
toyota man's picture
I am using my xlr outputs to feed my amp can I use the optical or coax out put at the same time to feed a cd recorder / headphone amp/dac without affecting sound quality many thanks for any help with this one
__________________
nads
nads's picture
RE: toyota man wrote:I am using
from what magic box is this then?
__________________
Not a HiFi Nut. Just has a pile of Nads.
Dr Lodge
Dr Lodge's picture
I'm guessing this source component is a CD player, which has analogue outputs (XLR possibly phono too) and digital outputs from the transport (optical/coax). Wouldnt think there's any problem in using multiple outputs for different ends i.e. XLR outputs to drive the amp/speakers, and digital output to drive a DAC/headphone amp. Might run into problems if you used both XLR and phono outputs at the same time, my Wadia has both but I think the shop I bought it from said I could use both of these too (dunno why I'd want to tho).
Give it a try and see, it'll certainly work to some extent and won't damage anything. Of course the optical output is electrically isolated so can't see why using this as well as the XLR should make any difference at all.
__________________
HiFi #1: Wadia 861 CD & digital i/o | Transparent Ultra MM Balanced | Muse Electronics Model Three Hundred Monoblocks | Townshend Isolda Biwire | ATC SCM40s | Partington AV Minim with granite shelves | Samsung PS50Q97HD | Humax FOX Sat HDR | Sony BDP-s470 | Cambridge Audio DAB500
HiFi #2 : Squeezebox Touch lossless FLAC | DNM Interconnect | Merdian 206B CD | Cable Talk Broadcast 2s | Denon DRM-600 deck | MF FM1 Tuner | AR EB101 TT w/Roksan Blue | MF P-100 pre | DNM Interconnect | MF X-A200 power | Nordost Flatline triwire | EPOS ES30
