27 posts / 0 new
Last post
whoam1's picture
Last seen: 3 years 1 month ago
CAMBRIDGE AUDIOSTREAM MAGIC 6 - Alternative
I went out yesterday to purchase the above.
However, I wasn't aware that it didn't support Spotify.
Any suggestions as to an alternative system with built-in Spotify.
Not Sonos please as the sound quality was somewhat lacking compared to the Magic 6.
Cheers.
tino's picture
Last seen: 4 days 13 hours ago
RE: CAMBRIDGE AUDIOSTREAM MAGIC 6 - Alternative
What amplifier / speaker combination are you using?
SBT • Wadia 151 • Aliante PF
CnoEvil's picture
Last seen: 3 days 15 hours ago
Linn Sneaky, but you have to stream it as described here:
http://forums.linn.co.uk/bb/showthread.php?tid=3149
"We should no more let numbers define audio quality than we should let chemical analysis be the arbiter of fine wines."  Nelson Pass
whoam1's picture
Arcam AV9/P7 with Sonos Faber Grand Piano speakers.
CnoEvil's picture
Very nice indeed.....and the Linn DS will fit in well with this.
whoam1's picture
Thanks, I will go and audition the Linn kit next week.
As an aside, could I connect to the Magic 6 via Bluetooth and stream Spotify that way?
What sort of sound quality would that provide?
Shanka's picture
Last seen: 1 year 2 months ago
Out of curiosity why not Sonos through a dac Magic plus or other dac which would improve the quality.
I looked at the spotify ds set up and looked tricky but I admit I'm not very techy.
whoam1's picture
I did consider the seperate DAC approach but I suppose I was looking for a simple, one box, plug-it-in-and-away-you-go, solution.
Having read the Linn DS/Spotify link posted, it does indeed look a little convoluted.
CnoEvil's picture
Auditioning the Linn is a good idea.....try and use kit as close to yours as possible.
As for your other questions....not a clue, sorry.
(Welcome to the forum, btw)
Shanka's picture
I use spotify through a dac in my second system with a dacMagic and am quite happy with it, I have tried Spotify on Sonos using my mobile which was equally easy to use and you get the other benefits of Sonos.
I know you can get it also on Squeeze Box Touch but have not seen it work but many here seem more than happy with it, it is cheaper and you could then spend more on a DAc maybe.
I do not know how these compare with the operation of the Linn, maye CNo can advise if required on his next visit.
tino's picture
You could do that, but you can also do the same with the cheaper DacMagic Plus and matching BT100 Bluetooth receiver which uses the apt-x audio codec (see http://www.cambridgeaudio.com/summary.php?PID=872)
I stream music via Bluetooth (apt-X) using a Chordette Gem. It's not as good as a wired DAC connection, but I'm very happy with the sound quality and it's very convenient to use. Used ones are about £200. Using one I can stream Spotify from a PC, iPod or tablet. You need to use an apt-x transmitter for about £30-£40 for decent sound quality, the plain old Bluetooth SBC codec isn't up to much sound quality wise.
BTW ... with the amplifer you have I assume you have a nice AV setup. However if you wanted an all in one excellent sounding stereo setup (with amplifier), and do justice to those SF speakers you have, then I would look seriousky at a Linn Majik DSM.
John Duncan's picture
Last seen: 4 days 14 hours ago
Add an Airport Express and stream Spotify from iPhone via AirPlay or PC using Airfoil software, or get a Squeezebox Touch and DACMagic Plus...
Moderator: john.duncan.whf at gmail dot com
System burgeoning
whoam1's picture
Thnks for all the input and suggestions; most welcome.  Smile
I am going to audition the Linn kit later this week. The local dealer is pretty accomodating so I will take the kit home to try if I like the demo in the shop.
Am also going to have a look at the Bluetooth connectivity suggested.
My conncern about that is that I've read about issues with drop-outs etc.
Any views?
CnoEvil's picture
That is the best way....make sure you have a good listen to the Majik DS if in budget, as it is worth the extra (imo), as it's the cheapest DS to have the Dynamik power supply.
Look forward to what you think
Cno
Anonymous's picture
Hi Tino,
I just purchased the Cambridge Magic 6 and I'm totally confused regarding a few issues.  Your help would be greatly appreciative!
1) Once I've copied my CD's onto my computer using i tunes, how do I then "send" that music over to my Magic 6 component????
Thanks again,  Dan
Anonymous's picture
UNPUBLSIHED BY MODS - DUPLICATE POST
Hi Whoam,
I just purchased the Cambridge Magic 6 and I'm confused about a few tech issues.  Your help would be greatly appreciated.
1) What devices could be "hooked-up" to the rear of the Magic 6 component?   (and for what reasons?)
Also, does it make sense to connect a receiver up to the rear of the Magic 6?
Also, I've copied my CDs onto my computer by using i tunes.  Now, how do I "transfer" all of that music over to my
Magic 6 device so that I could listen to it.    Thanks!
Pages
Log in to post comments
