Cable in - Phono stage - Cable out
8 replies [Last post]
camcroft
camcroft's picture
Hi.Do you think it is advisable to use the same make of cable on both sides of the phono stage from the tt and onto the amp.Thanks puzzled
__________________
Marantz SR5023 - Marantz CD5003 - Project Debut Carbon Turntable Black gloss with acrylic platter & Rega Mini phono stage with Atlas Element Integra cables;Monitor Audio RX1 Black gloss Speakers.-Chord Carnival speaker cables.Atacama Nexus 7 speaker stands
The_Lhc
The_Lhc's picture
Online
RE: Cable in - Phono stage - Cable out
Depends, have you found a BOGOF deal somewhere? Other than that, not really.
__________________
No signature worth mentioning...
ISAC69
ISAC69's picture
Yes because each cabel has its own characters
__________________
Hi Fi : ROKSAN KANDY K2 - PROAC STUDIO 140 MK2  - ROTEL RCD1520 -  interconnects : Tellurium Q Black - Chord Chorus2
AV : YAMAHA RXV767 - INFINITY PRIMUS PS8 [SUB]
chebby
chebby's picture
Online
Not if the money spent  could yield more improvement by getting a better cartridge instead.
I don't know what your cartridge is and I don't know how much you plan to spend on cables. So I can't comment on cables vs cartridge upgrade in your system. Speaking personally, my Regas never had the option of matching the cables as you describe because they all had 'tethered' signal cables wired straight  into the arm and so it never bothered me.
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Apple iPad Mini • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
camcroft
camcroft's picture
Hi.Chebby.The cartridge is a Ortofon 2 red and the cable from the Project turntable to my Rega mini phono stage is a Qed Quinex 2 and on the other side is a Atlas integra element to the reciever/amp
__________________
CJSF
CJSF's picture
Hi camcroft, cables in my humble opinion are a soft option and from what I read on forums lead to going round and round and . . . you can spend a fortune and eventualy disapear down the hole in the center of the record! . . . cleaned that one up Smile
I think Chebby has a point with improving the cartridge, big improvements here, depending on budget.  I have spent the past 2 years upgrading the front end of my system, it did not cost me a fortune but required patience, time and personal honesty at each change or adjustment, 'better, worse, no different or a sidways move'?  Takes time and understanding, understanding comes with the time.
I got to a point where the front end signal was obviously so good, it was time to look at the rest of the system, to make the best of the SQ and effort put in over the two years.  The thinking is, why bother to fiddle and faff with cables, amps, speakers if the origin of the signal is not up to standard.  This is not a new idea, goes back to the early days of Linn; "rubbish in, rubbish out" . . . if infomation is lost at the point of source, you cant add it later.
CJSF
PS something I found that has been a tremendouse help, the use of a digital stylus scales, around £25 on fleaBay.  I new that stylus presure changed the sound a suprising amount, but the Rega arm markings were wowfully inacurate I discovered.  Now I can repeat a downforce to within 1/100 of a gram every time!  Dont sound like much I know, but it was a big step forward for me, accuracy and repeatability is everything I found.
These are the scales I use:  200796934351 . . . but these are the latest version: 350322574886
tifosi20002008
tifosi20002008's picture
Hi
In the ideal world both in and out cables should be the same.  But if that sound works then thats all that matters.
Buy more music instead.
beauty, eh
__________________
Where ever you go, You're already there.
Creek Evolution 2 amp, Exposure 2010s cd player, Usher s520 speakers, benchmark dac, Technics sl5 turntable.  Assorted chord and tellurium cables.
camcroft
camcroft's picture
Thats what i am doing in between waitng for my answers
__________________
altruistic.lemon
altruistic.lemon's picture
Online
Cable from the tt to the phone preamp should be the lowest capacitance and resistance you can find, plus not be too long. Brands don't matter to that extent. Preamp to amp - what you've got is fine.
