B&W diamond tweeters
14 replies [Last post]
power
power's picture
I have a pair of 805Ds and one of the tweeters is playing intermittently. I want to check whether its the tweter thats broken or something else. I want to do this by swapping the tweeter fro the working speaker and trying it on the speaker with the tweeter thats playing intermittently.
How does one remove the diamond tweeter of the B&W speakers to do this? please help
__________________
Harman Kardon AVR660,Harman Kardon BDT30, B&W ASW610, B&W CM8, B&W CM Centre 2, 805Ds as rears, Harmony 1100
ellisdj
ellisdj's picture
RE: B&W diamond tweeters
Hello Mate
If the tweeter housing is anything like the N805 then you twist the front of the housing anti clockwise to unscrew it - then remove the 2 cables at the rear and the tweeter should come off.
When you remove the outer cage I would put it down, dont keep it in your hand, you dont want to dimple / mark the tweeter - speaking from experience .....
If you are unsure call B&W in Worthing they are very helpful and could tell you exactly Wink
__________________
Meridian G61R, HD621, G55, MC200, MS600
Panasonic 65VT65, Marantz UD7007, HIFi Racks Podium Reference
Monitor Audio GX100, GXC150, Apex A10, BK XLS400 (set with hard knee house curve)
Graham Slee Spatia (SC) Graham Slee Cusat 50 (IC x 5 Analogue,x 4 Digital)
Big Aura
Big Aura's picture
Given you're asking how to on here, this may be a job that's too tricky for you!  How long have you had them, IIRC B&W come with a 5 year guarantee.  Speak to your dealer first!
__________________
I have some home cinema and Sonos stuff.
power
power's picture
I got them 2nd hand which invalidates the guarantee. what is the likely cause of the tweeter to play intermittently? Is it a sign that the tweeter is on its way out or something else?
__________________
power
power's picture
Anyone out there with the knowledge of the cause of an intermittent tweeter please advice on the most probable cause of this. Your advice will be appreciated
__________________
Andrew Everard
Andrew Everard's picture
Could just be a loose connection – but it may be in the crossover, the terminal panel or the driver itself.
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
power
power's picture
I took it in today to be checked out today and I hope it'll be sorted out. I got this speakers at less than half price of a brand new pair.
__________________
power
power's picture
I took them in today back to the shop I bought them from to be checked out. My fronts are CM8s and I didnt have rears for a while and then I came across this 805Ds. Will they become a complete mismatch to my fronts? Is this where I trade in my CM8s for 804Ds?
__________________
ellisdj
ellisdj's picture
I would also probably use the 805Ds as fronts as they are a much better speaker than the CM's
Having CMs as front and 805D's as rears is a crazy mix Smile makes me really laugh though - stunning rears to have - the 805's are so transparent they would be an awesome rear lucky you
I would upgrade my amplification before buying any more higher up the chain B&W speakers mate
They require the finest amplification money can buy with a lot of current / power.
Get the amplification as high up the chain as you can afford / fit into your system, then look to add even more demands i.e. 804 to your system - that will be a stunning system no doubt though
804 D fronts with a HTM4 D centre then the 805D as rears - you will need proper power amps like bryston etc to get that system properly going.  An AV amo is not going to get the best from them, nowhere near Wink
However with a good acoustic room I doubt there is much better out there. different but I doubt much better without going silly
__________________
Rethep
Rethep's picture
Just be a little patient! First have them in wright order and listen for some while. (Re)position them and listen again. Then think about other options.
__________________
Airport Express (still analog)/Meridian 206B (cd-player), Artephonos Energa (power-tube-amp), Epos ES-11 (speakers). Panasonic TX-P42G30 (tv).
power
power's picture
Im already regretting why I bought them bcs they may push me to upgrading my entire system. Ill have to think carefully befor I make my next move. I may moth ball them for a future project. I'll see but Im very confused right now
__________________
ellisdj
ellisdj's picture
Dont be like that - once they are fixed enjoy them - very very good speakers, I loved my N805 and you obviously love B&W so will no dount love them
the N805 were super refined, lovely listen
You could always go the 4 x 805D 1 x HTM4D and use the sub - then you will have a very high end sub satellite system that if you read the what hifi review for the 805S x 5 setup they say its right up there with the very best
They definately thrive on power and space like most good higher end speakers - amazing rears, I would def try them as fronts to see how they fair against the CMs - I dont think you will be putting the CM's back once you have heard them.
Maybe consider biamp off your av amp if it does it - I have found that to help with harder to drive speakers, worth trying Wink
__________________
power
power's picture
Im using an HK avr660 which is high current(60 amps. I am impressed with how much authority it has over most speakers. It pushes my CM8s with great authority but I wonder if its good enough to push the 804Ds and 805Ds together.
__________________
ellisdj
ellisdj's picture
It will still work ok, providing excellent sound no doubt, but to get the max out of the 800 range of B&W you need something like this http://www.whathifi.com/review/classe-ca-5200 or similar - proper power amps, not an av amp.
Something to consider as part of your upgrade route, amp might be better than speakers -
__________________
power
power's picture
You are now talking mega bucks which is out of the question. Im in South Africa and Classe here is not for poor people like me. I think moth balling the 805Ds and sticking to my CMs will be a good idea and then going in ceilings for rears for now. Ill put them into use some time in the future when I can afford decent amps to go the 800 route
__________________
