8 posts / 0 new
Last post
ABM78's picture
Last seen: 1 year 1 week ago
Burson Audio Buffer
Local brand here in Australia, thinking about adding one to help my NAD545bee sing some more, have a friend in another state has one and loves it, read reviews and seems postive, on the off chance anyone on the forum has any experience with it? I hear MF used to sell a similar product? Any thoughts? Seems a fairly cheap way to try maximise the performance without spending more than twice the price on a better cd player. Loving the new Leema Pulse, but you know what this is all about loving it then trying to love it even more! he he
Anonymous's picture
RE: Burson Audio Buffer
Yes, I used to have the MF one. Makes more difference between some mismatched equipment, but still made a worthwhile difference between (presumably already matched) MF components. I think MF incorporated the buffer into some of their amps as standard, not sure tho.
plastic penguin's picture
Last seen: 4 hours 16 min ago
No idea about 'Audio Buffers'. How much do they cost? might be worthwhile going for a s/hand CDP, such as Arcam 192. Leema and Arcam are a cracking match....
Leema Pulse; Arcam CD73; PMC TB2i; Pro-ject Xpression with a ClearAudio cart; Denon TU260 MKII
ABM78's picture
Thanks PeteAllen for the feedback, PP the Burson Audio Buffer is about equivalent 320 pound here, while this might not sound like a relatively inexpensive upgrade, if I were to look at such a player as a Rega Apollo as an upgrade I am looking at over 1200 pound delivered to the Northern Territoy from southern Australia somewhere! The second hand market here is just nothing like what you guys have there, just did a google of Arcam, no results locally. If interested with the Audio buffer do a google and check out their site, they deliver internationally, I just don't think I can go out and spend that money on a new CD player, if I were to spend the money it would be upgrading to Dynaudio focus range.
Anonymous's picture
I have the Burson HA-160D already and it is very good. If their standalone dac is better than the dac section of the HA-160D, then it is well worthwhile upgrade to your NAD (keep it and use it as a transport. The HA-160D has a really good preamp built in too, however the volume control is a pain.
Anonymous's picture
why is the volume control a pain?
Anonymous's picture
Because, as a (better quality) alternative to ALPS etc style volume controls, they have lots of discrete positions with separate resistors for each volume setting. Between a few of these volume points, I get loud clicks on one or both channels. Actually I can get around this by doing it slowly, then it is a smaller click. There is no remote.
I checked with Burson, they say the HA-160D has the same audio buffer on the preamp inputs.
ABM78's picture
Picked up one of these for $250AUD, really has opened up the sound, bass has far more heft and definition without going flabby, definitely a worth while addition to a system I was already happy with.  Reccomended.
Log in to post comments
