Budget £1300-1500 amplifier and a pair of bookshelves, suggestions please??
26 replies [Last post]
aniskg
aniskg's picture
Hi guys
As the tittle suggest I have a budget of around £1500 and looking to buy a good amp and pair of speakers to go with it.
Here's a little story how I actually got into the whole fine-sound affair:
I am a musician myself, I play the Indian percussion instrument called tabla. During my teenage time, oneday I went into Birmingham richer sound store inquest of finding a hifi system that would sound better than what all my friends and cousins had at time in the likes of aiwa, kenwood, technics, etc. Quite naturally  I saw brands that I never heard of before, I had not much to spend either but luckily for me they had a sale on. I am talking about early 90s so no Internet to do any research before buying, so what  do I do? I looked at this beautiful looking amp it was called musical fidelity e10 integrated amp it looked nice and simple and also the name caught my imagination and I decided to buy it, don't remember how much it was, I also bought a cheap Marantz cd player. In terms of speakers I knew what I was looking for. I was looking to buy Bose but richer sound didn't sell them so the salesman suggested BW dm601 and again I was impressed by looks and their  yellow kebler.
So this was my first pure hifi set up and I have been really pleased with the sound.
Recently on my trip to India i bought a what hifi magazine to read on the plane, here I came across the much talked Marantz pair pm6004 and cd6004 and also learned about DAC. Since I had my old system for almost 20 years I thought this may be the good time to upgrade my system, after doing bit of research I bought the Marantz pair, I felt rather sad as I unconnected my old MF anyways after setting up the system I played few tracks. And felt a bit disappointed I thought may be it needs burning in time so played it for few hours, nothing changed only a sleepless night. I kept thinking maybe it's the speakers because they are old they are not performing well with the new system so next day I decided to hook up my MF back on to see the difference and guess what??? With the new Marantz cd player my old MF sounded like it had never sound before ,I thlnk the built-in DAC made the difference. I straight away put the pm6004 back in its box.
In my current financial situation I could never have imagined to setup such a budget as I have, but having spoken to a couple dealers they said, to upgrade from my existing setup I would have to spend such money to feel any difference.
As you can tell I am a big fan of MF products and contemplating m3i but the other names such as naim, rotel, creek, roksan, audiolab do also come to mind. Speaker wise I think I will have to wait till I decide on the amp.
I listen to Indian, jazz, pop, indowest fusion, bit of rock, strings and vocal based music, nothing rhymed is one of my favourite English song of all time.
Preferences : tight and controlled bass, high note should be as clear as low note, detailed sound, every instrument should get its respective space and most importantly it should sound sweet and musical.
Thank you for reading my story.
Awaiting recommendations
Seasons greetings
MUSICRAFT
MUSICRAFT's picture
RE: RE:£1300-1500 amp +pair of bookshelves, suggestions please??
Hi aniskg
What is the size of your room?
Are your current speakers stand, shelf or wall mounted?
Listening distance?
Your general listening level?
Interconnects and speaker cables are?
Btw, i've never heard of the tabla Wink
All the best
Rick @ Musicraft
__________________
Musicraft (Derby), Specialist Hi-Fi/AV & Multimedia Dealer
good accurate audio monitoring and good sound reproduction to all Smile
David@FrankHarvey
David@FrankHarvey's picture
RE:
As you say, the M3i is your first stop, to which you can add something like Monitor Audio RX1's or RX2's, Acoustic Energy Radiance 1's, KEF R100's, or ATC SCM7's.
The Naim Nait 5i will go particularly well with the Rega RS1's and KEF R100's.
The Rotel RA12 will go well with the B&W CM5's, KEF R100 or LS50's, Acoustic Energy Radiance 1's, and Dynaudio Excite X12's (or even X16's). This amplifier will also add a USB connection as well as other digital inputs to use for other digital sources.
The Audiolab 8200A will pretty much work well with the same speakers as the Rotel RA12.
Based on your stated requirements, I wouldn't ignore the new Pioneer A50 or A70 amplifiers. They may have been out of competitive hi-fi for almost a decade, but they've come back with a stonking range which is probably the best built kit under £1k. Their Class D amplification exerts a tight grip over the speakers, and the A50 in particular can drive speakers that other similarly priced amplifiers just can't do. Very clean, tight, and controlled. Both of these amplifiers work extremely well with the KEF LS50's, which also exhibit the same characteristics, and produce a soundstage free from any box colourations.
Most of these systems will fill the average size room, and in the quest to preserve quality, I'd stick to standmount speakers rather than floorstanders, as you'll generally get more quality for your money.
__________________
David @Frank Harvey Hi-Fi, Coventry
Mitsubishi HC7000 / Oppo BDP103 / Audiolab 8200AP / Rotel RMB1575 / kick ass speaker system
Overdose
Overdose's picture
RE: Budget £1300-1500 amp and bookshelves.
Seasons greetings
You might be able to acheive your goal at a lower budget, but for me, the best value for money at  your budget would be the ADM9 active speakers, in their latest incarnation, which I beleive are the ADM9 RSS.
Have a read of the link, but in brief they are DAC, preamp, active crossover and power amps within the speaker enclosure.
I have active speakers myself and find them to be excellent, but the ADM9s would certainly be on my short list should I decide to go for a change.
__________________
Mac mini > AVI ADM9Ts
CnoEvil
CnoEvil's picture
Online
My suggestion is to listen to as much as you can, but for me the MF M3i + Kef R100 will be very hard to beat (provided the room isn't too big).
__________________
"Everything has been said before, but since nobody listens we have to keep going back and beginning all over again."  André Gide
Ketan Bharadia
Ketan Bharadia's picture
RE: Budget £1300-1500 amplifier and speakers?
The combination is below budget, but Rega's Brio-R with Neat Iotas will work really well in small spaces.
__________________
Technical Editor, What Hi-Fi? Sound and Vision
aniskg
aniskg's picture
MUSICRAFT wrote:
Hi aniskg
Listening distance?
All the best
Rick @ Musicraft
Hi there, thanks for your reply
My room size is 14 by 12, speakers are standmounted, listening distance about 8 feet, interconnenters are all Cambridge audio. Will buy new speaker cable with new system. Listening level : on my 40watts amp I hardly go above 50% on the volume knob.
aniskg
aniskg's picture
aniskg wrote:
MUSICRAFT wrote:
Hi aniskg
Listening distance?
All the best
Rick @ Musicraft
As for tabla you can you tube it there are loads of video on tabla
aniskg
aniskg's picture
RE:
Thanks Frank
I quite like the looks of AE but will listen to MA and kef before pulling the trigger. As for amp I gnna stick with my favourite MF
aniskg
aniskg's picture
rockin out hi ketan this is all I can afford for now so may if I spend about 1k to 11 hundred on the amp and buy speakers with the rest.and few years down the line I can upgrade the speakers
DIB
DIB's picture
RE: Budget £1300-1500 amplifier and a pair of bookshelves
Seeing as you mentioned Creek I would suggest an Evo 2 amp matched up with the Epos Elan 10 speakers. Around £1250 for the pair and should make a great combination. I'm currently home demoing the Epos Elan 30 floorstanders with my Creek Evolution 5350 amp and it sounds wonderful.
__________________
Speakers: Epos Elan 30
richardw42
richardw42's picture
Seasons greetings
+1. For the budget, this is really the only answer.
Any other answer is just wishful thinking and won't come close.
__________________
TV room : Samsung 60" plasma-ATV3, Denon DBP2012UD-Yamaha RXV3067-AVI ADM9RSS,MA RSW12,/Sonos ZP90 via optical, Sky+ HD & Sky Connector, PS3
HiFi : Sonos ZP90 - AVI ADM40
Bedrooms : 2 x Sonos Play 3
Ipad for Sonos & Spotify
the record spot
the record spot's picture
Really Richard?  Why's that then?  By who's yardstick?
__________________
Onkyo TX-8050 / Tannoy Revolution DC4 / Marantz SA7001-KI / Apple TV 3 / Sony PS3 320Gb / Denon DVD-3930
jjbomber
jjbomber's picture
In their cult meeting last Thursday morning. It's Chistmas. Good will to all men and AVI cult members.
richardw42
By mine
Latest speakers make my previous more expensive passive set up look silly.
But I wouldn't expect you to agree RS even though I think you know it's true.
__________________
the record spot
Hi Rich, you suspect wrong.
I've never thought thought that when I spend £1200 on a pair of speakers, the internal wadding should be gawping out at me.  More of a Genelec man y'see.  Plus I like the flexibility to dictate change on my terms.  If I want to change the DAC, amp or whatever, I go ahead and do so.  Plus I dislike AVI, or some of its employees', attitudes to the audiophile world.  Simple as that really.
__________________
