New Azur hi-fi range arrives from Cambridge Audio
Cambridge Azur 650
These are completely new designs and replace the 540 and 640 series. There are two new integrated amplifiers – the £300 550A and £350 650A – joined by two CD players, the £280 550C and £330 650C.
A new DAB+/FM/AM tuner will follow later this year.
Designed from the ground up at Cambridge Audio's London-based research and development facility, the company says these new models "adhere to our legendary combination of outstanding performance, innovative design, meticulous construction and immense value for money".
Latest Videos From
Low power consumption in standby
What's more, the new Azur range has a stamp of approval from Energy Star thanks to each component's power consumption of less than one watt in standby mode.
To further enhance its green credentials, CA has used recyclable packaging throughout the range which is manufactured from 90 per cent recycled pulp and uses soy-based environmentally-friendly inks.
There's a new look to the exterior casework of both amps and CD players, with new displays and controls, a thicker brushed aluminium front panel, seamless wrap-over lid assembly and dual-layer damped feet. This contributes to better resonance control, claims CA.
But there's more to these new models than a fresh set of clothes. Cambridge Audio has taken an 'audio first' approach to musical reproduction and made improvements beneath the skin, as listed below:
Cambridge Audio 550Aand 650A amplifers
650A - 75 Watts RMS into 8 Ohms
6 inputs, 2 outputs and Tape In
Revised output stage using new Sanken output transistors with external emitter resistors for reduced thermal modulation and increased current delivery
New ALPs film type 'black box' volume pot for improved low-level channel balance and stereo imaging
Audiophile grade toroidal transformer and substantial extruded heatsink
Updated and re-tuned CAP5 protection technology to enhance performance at high volumes
New low dissipation polypropylene signal capacitors and custom made electrolytic capacitors in critical positions
Buffered input circuits for low crosstalk and improved stereo imaging
Control Bus and IR Emitter In connections for simple multi-room integration
Pre-out for connection to external power amp or active sub
EnergyStar certified ultra low power (<1W) standby circuits
Front-mounted iPod / MP3 player connection
Gold plated low-loss hi-fi speaker terminals
LED indicator shows which speakers (A, B or A+B) are selected
Supplied with new Navigator remote – also controls Azur CD players and docked iPods
Cambridge Audio 550C and 650C CD players
New proprietary Cambridge Audio S3 servo solution
Wolfson WM8740 DACs (Digital to Analogue Converters)
550C Three-Pole Double Virtual Earth Balanced filter topology
650C Four-Pole Dual Differential Double Virtual Earth Balanced filter topology
All PCBs and DAC stages now feature double-sided surface mount technology to eliminate wire links and giving shortest possible signal paths
Highly accurate master clock oscillator and carefully designed impedance-matched clock buffering schemes
CD-Text display for suitable discs
New low inductance Metal Electrode Face resistors to further improve performance
New selectable choice of sharp roll off or slow roll off filters
New high contrast reverse black DFSTN (Double Film Super Twisted Nematic) display
Supplied with new Navigator remote - also controls Azur amplifiers and docked iPods
All models are available in silver and black. We'll be receiving our first review samples on May 29th.
What Hi-Fi?
What Hi-Fi?, founded in 1976, is the world's leading independent guide to buying and owning hi-fi and home entertainment products. Our comprehensive tests help you buy the very best for your money, with our advice sections giving you step-by-step information on how to get even more from your music and movies. Everything is tested by our dedicated team of in-house reviewers in our custom-built test rooms in London, Reading and Bath. Our coveted five-star rating and Awards are recognised all over the world as the ultimate seal of approval, so you can buy with absolute confidence.
Read more about how we test
