Brio R with RX6 not a good match?
21 replies [Last post]
Mikejekel
Mikejekel's picture
Hi Guys, Since a year now, I own a Brio R with Rega dac and MA RX6. The previous set-up was Brio R with MF v-Dac and Wharfedale 9.1. Back then the system was very nice and warm sounding. Only thing I felt it lacked was that bit of the lower end. So, I started looking for (compact) floorstanders. After auditioning B&W 683/684, Elac, Focal, Dali MA RX8 and RX6 I went for the RX6 because I felt they had the perfect balance between bass and treble. However, I am not really happy now that I have it at home. I don't know the right word but it's just not nice to listen to. It's very detailed and fast, but no warmth at all. Best word to discribe it would be harsh. I gets worse the more I increase the volume. I can only blame the RX6 because it wasn't a problem with the 9.1. It also applies to both Spotify premium and Vinyl, so that rules out the source. I just read some fora about the Brio and find some recommendations for partnerring them with the RX6. So I don't understand what could be wrong. I was thinking of maybe changing cables but I doubt that is worth it. Any thoughts?
__________________
Dual 701/Spotify premium -> iPhone 4S -> AirPlay -> Apple tv 2 -> rega DAC -> chord crimsonplus -> rega brio r -> dynaudio excite x12
floyd droid
floyd droid's picture
RE: Brio R with RX6 not a good match?
Nowt wrong mate per se. Its just that you dont like that pairing ,end of. Lesson learnt , assuming I have got the drift of your 'dem' efforts correctly ?.
You will no doubt get 'I have that set up and its fine, not harsh at all '. Well they dont have your room or ears do they.
Next time dem at home.
Mucking around with cables is the road to ruin.
stevebrock
stevebrock's picture
I took some Neat Motive 3 home, sounded rubbish with my Brio R but sounded so good in the shop demo room!
Lesson learnt........
Took some RS1 home - hifi nirvana resumed!
__________________
Synology DS212j > Rega DAC > Rega Brio R > Rega RS1
Rega RP6 / Exact
Chord Chameleon Plus / Odyssey 2
Panasonic TX-P50 GT50 > BDP110e > Yamaha RX-V 667 > Rega Vox
BigH
BigH's picture
Have you run them in for over 70 hours? Is your room a lot different from the demo room. If you don't like them then contact the shop and explain situation and see if you can trade them in for something else, they may swop them for an demo pair. How about the Rega speakers hear they are good.
Hi-FiOutlaw
Hi-FiOutlaw's picture
Hi Mike
that is quite normal, there are differences between the shop demo room and your space, there are already good advices on the thread, like the burning in time, i don't know your cables, are they pure cooper or they have a mix of silver? Try some pure cooper cables, the MA RX6 have a metal dome twiter and with a reaviling amp like the Brio R is they tend to sound a bit bright, and if you add to this mix a silver cable even worst.
I know this from personal experience, i own MA RS1, MA B4 (and i have a cooper cable with a tin bath) and compared with my Dynaudios they are not so warm even with a cooper cable.
The RX6 are a magnificent set of speakers there is no problem if they are not for you, the same thing go to the Brio R.
It is my opinion as well if all this fail you shoul try some Rega RS3 or 5.
Try first some cheap 100% pure cooper cables, and start from there.
Tell us about your findings.
beauty, eh
__________________
LivingRoom
Rega RP3 / Goldring 1012gx # Synology DS213 > QED Performance USB > Rega DAC > QED Performance RCA > Rega Brio R > Supra Classic 2x4mm > Dynaudio Excite X12 and some times BK XLS200 MK II
BedRoom
SBT > G&BL teflon line RCA > NAD 3020i > Supra Classic 2x4mm > Monitor Audio RS1
CnoEvil
CnoEvil's picture
Bright detailed and forward can sound exciting over a short dem....living with them is another matter.
Copper cables are certainly worth a shot if you have silver coated ones.
__________________
"Everything has been said before, but since nobody listens we have to keep going back and beginning all over again."  André Gide
Mikejekel
Mikejekel's picture
Thanks for your great help, much appreciated.
To answer some questions;
- Yes, I only demo'd in the shop. Did use my own amp. The room is definately different from mine. Mainly the distance is shorter from the listening position, approx 3,5m in my room vs 6 in the demo room
- I guess it should be burned in by now. I listen almost daily for about a year now.
- I did change my currect cables (don't know silver or copper) with pure copper. No noticable effect.
- I guess going back to the shop and explaining the situation is the best way to go. Although I'm not sure if they will take back anything after a year. Wouldn't mind some ex-demo btw.
__________________
floyd droid
I would imagine theres a slim chance that the answer to that will be yes.  rolling on the floor laughing
Obviously you didnt read the OPs post.  ;).
BigH
BigH's picture
Sorry missed that part. Well after a year you probably won't be able to change them unless you can do a swop with some ex-demo ones. Best bet is to try a home demo if you can.
Hi-FiOutlaw
Mikejekel wrote:
In that case...
Sell your MA RX6, you should get nice money from them, and start looking for a new set of speakers, demo some Rega RS3 and 5, Epos Epic 5 this are speakers that I demo myself with the Rega Brio R and found them very warm.
Good luck on the RX6 sale!  ;)
__________________
LivingRoom
BedRoom
Rick1979
Rick1979's picture
 How odd! I know there is a slight difference but my rs6's sound a little boomy on some music with my brio r, fed by an rdac. I blame the damn rdac. Crying
Coll
Coll's picture
I have the Brio R with RX6 and Audiolab CD player,works for me fine and by the way I have copper cables.
But obviously even the same system in another room and with different ears it my not suit everyone.
I think of them as detailed but some may say bright.
__________________
Mikejekel
Mikejekel's picture
Anybody advice on "warm"speakers? Preferably (compact)floorstanders, otherwise stand mounts are ok as well. I noted the epos epic 5 and don't like the look of the rega rs3/5 due to the side woofer.
Thanks again!
__________________
radiorog
radiorog's picture
 If you go the standmount route...Dynaudios. I have auditioned with dm6's and they were very sweet souding. detailed yet warm, and sweet treble. I am soon to demo with my own dm7's, and I expect buy the brio r. My doubts with dynaudios and the rega is whether the speakers will be driven properly....they did sound v good tho. It is a question i will ask the dealer when i go in, as you can't ask rega direct.
 Hi-Fi Outlaw has Dyn. Excites, it would be good to hear how he is finding them now after a little time running in with the mentioned amp.
 I was after some floorstanders for a long time, thinking that is what i needed for bass weight, until i recently heard my brothers BX2's and was amazed at the sound quality and bass depth of modern medium priced standmounts, and immediately changed tack and bought some nice standmounts that can actually fit in my small room.    Smile
__________________
cambridge audio 651c, sherwood ax 4103, dynaudio DM7
csq2
csq2's picture
No offense, but the MA RX6 are horrible sounding for the money. The Brio-R is amazing, so I would try to change the speakers if you can. Epos Epic 5 are much better sounding than the RX6 for similar price, even though Whathifi gave them a descerning 4 star rating. Don't believe in 5 star ratings, the PSB T6s and KEF Q700s are also better sounding than the RX6. My Klipsch's are too.
__________________
USB->Hegel HD2->Coaxial->Onkyo A-9070->Klipsch RF-62 II
rtaylore
rtaylore's picture
I have a Brio-R and I think it sounds great with my Tannoy Revolution Signature DC4Ts - used to be available from Richers, but now I think only in clearance/ex-demo.  I paid £600 for the Tannoys, you may be able to get a better deal.
I've never done any serious demo-ing but someone here referred to the Brio sound as 'grippy' which I think is spot on.  I think it tends towards warm sounding too.  Anyway, I absolutely love this combo and the Tannoys are certainly compact and gorgeous to look at.  Much better than the MA BX5s or BX6s (sorry I can't recall which) when I had a speaker demo at Richers last year.  I found the bass quite flabby, and overall less detail than the Tannoys.
My room is small, just 4m x 4m
Hope this helps.
