11 posts / 0 new
Last post
Lo Fi's picture
Last seen: 3 years 5 months ago
Bright Speakers
Stoff 1 wrote:
An update, have put a piece of toilet roll over the tweeter and that has really smoothed things out. Very happy with the result. It looks like the cyrus MA parnership is now working, great because I like both brands. Seached through old posts and found one suggesting this, very useful. I will take the tweeter grill off and cut the toilet roll behind and replace the grill to tidy things up.Wish things are always this simple!!
I know some of the older members have seen this before but I thought it may be worth quoting this from an old thread for newer members.
So if you find yor speakers are on the bright side after running in intry this. It is much cheper thn changing speakers.
You could use anything that will absorb output from the tweeter handkerchief or some grille cloth.
The guy I have quoted had a Cyrus amp and MA RS8 speakers.
BigH's picture
Last seen: 2 months 1 week ago
RE: Bright Speakers
Not MAs again.
Listen to the music, not the hifi.
plastic penguin's picture
Last seen: 1 week 3 days ago
RE: Bright Speakers
Lo Fi wrote:
I know some of the older members have seen this before but I thought it may be worth quoting this from an old thread for newer members. So if you find yor speakers are on the bright side after running in intry this. It is much cheper thn changing speakers. You could use anything that will absorb output from the tweeter handkerchief or some grille cloth. The guy I have quoted had a Cyrus amp and MA RS8 speakers.
(Groan)
Leema Pulse; Arcam CD73; PMC TB2i; Pro-ject Xpression with a ClearAudio cart; Denon TU260 MKII
CnoEvil's picture
Last seen: 2 weeks 4 days ago
RE: Bright Speakers.....
.....My speakers are members of MENSA.....does that count?  :shifty:
"We should no more let numbers define audio quality than we should let chemical analysis be the arbiter of fine wines."  Nelson Pass
Lo Fi's picture
RE: Bright Speakers
BigH wrote:
Not MAs again.
From my point of view tlis was not supposed to be aimed at Monitor Audio it was meant to be a suggestion for curing any bright speaker speaker problem it just so happened that the original post was MA and Cyrus
alpne1's picture
Last seen: 3 years 3 months ago
RE: Bright Speakers
Seriously can you put cloth or such like over the tweeter without damaging the speaker ?
I have major problems bright !!  no shrill !!! yes. Changed QED silver anniversary to vanne damme with limited success. But this could work I guess ????
Cyrus 6a and Tannoy revolution not the best combo I guess.
Lo Fi's picture
RE: Bright Speakers
Yes if they have a grille over the tweeter already like with MA units, but not with the likes of Tannoy and Kef with tweeteer located in the middle of a speaker. But you could just try draping some cloth over the outside of the normal grille this would reduce output.
BigH's picture
RE: Bright Speakers
Why not just put a blanket over them they will sound and be a lot warmer.
BenLaw's picture
Last seen: 2 years 1 day ago
RE: Bright Speakers
Or a veil.
I am the danger.
DocG's picture
Last seen: 18 hours 37 min ago
RE: Bright Speakers
BenLaw wrote:
Or a veil.
And then after a while, you can lift it!
Downstairs: Bluesound Node2 -- DEQX HDP-3 -- 4 x Hypex NC-400 -- modded Magnepan MMGs
Upstairs: NAD M50 -- Devialet D120 (SAM) -- KEF LS50
Head-fi: in progress...
Hi-FiOutlaw's picture
Last seen: 1 month 1 week ago
RE: Bright Speakers
DocG wrote:
BenLaw wrote:
Or a veil.
There will be a KISS...?  :twisted:
Rega RP6/Goldring Elite MC>Clearaudio Basic Plus
Synology NAS>Auralic Vega>Pathos Classic One MKIII>Dynaudio X12
Log in to post comments
