Brand new CD player or DAC with existed Blu-ray player
21 replies [Last post]
Aries_Zhang
Aries_Zhang's picture
Just ignore my signature. I’m in the progress to setup my first Hi-Fi system. Speakers and AMP should be settled on Tannoy DC6T and Creek EVO2. Originally I want to buy the Marantz CD6004 to play CD and music on my iphone.
But after some research on the web, it seems there is another option. I have a blu-ray player Sony S380 which has coaxial out. And there are DACs with similar price as CD6004 (E.g. Arcam rDAC, MF M1 or a little pricey Rega).
So only compare the sound quality between the CD player and cheap blu-ray player connect to a DAC in this price range, which will be better? I would restrict the price under 500, so for the CDP side, will include Marantz CD6004, Rega Apollo, Creek EVO2, and on the DAC side, it will include Arcam rDAC, Music Fidelity M1 DAC, Rega DAC.
Any idea is appreciated. Please focus on the sound quality!
__________________
Marantz CD6004/Creek EVO2/Tannoy Revolution DC6T
jimm
jimm's picture
RE: Brand new CD player or DAC with existed Blu-ray player
I think a dac would be the better option, a Dac is flexible and can be used for listening to music through a PC or a streaming device. I use  the Musical fidelity M1 Dac, i love the sound from it.
__________________
Musical fidelity m1 - Nad c352 - Dali lektor 2
plastic penguin
plastic penguin's picture
Agree with jimm - A Dac is more flexible and you can use either a Blu-ray player or your Marantz as transport. I'd be looking at Arcam rDAC as minimum. If you're looking at dedicated CDP look at Creeks own Evo2 or Arcam CD17, but will generally work out more expensive.
__________________
Leema Pulse MKII-S; Naim CD5i MKII; Denon TU-260L MKII; MA RS6 speakers; Pro-ject Xpression 1; loads of different cables...
Formerly known as plastic penguin
Aries_Zhang
Sorry for the confusion. I've not owned the Marantz CD6004 yet. So I'm want to compare a CD player or a blu-ray with DAC.
As most music currently I have are on CDs, I mainly want to compare the sound quality on playing CD. If the CD player have better sound, I will definitely go for CDP. If not, sure, I will buy a DAC and enjoy the flexibility as a bonus. So the core is the sound quality of playing CD. help, I`m sinking
__________________
busb
busb's picture
I also recommend going with the DAC option. Doing so will mean any money you spend won't be wasted going towards a transport that you already have but soley on the DAC that you could then use to play computer based music at a later date. I personally believe the CD's days are numbered as a means of delivering digital music.
BR players need to stream reliably a hell of a lot more data per second than a CD produces so I'd put my money on a BRP being up to the task.
__________________
"The optimist proclaims that we live in the best of all possible worlds - the pessimist fears this is true."
James Branch Cabell
_________________________________________________________
MAINApple TV2 & iTunes Match, CA Azur 751BD or Panasonic P42V20B into audiolab M-DAC, feeding a Primare A34.2 via XLRs, 2x 5m of Atlas Ascent 2 firing up Totem Arros.
ON THE HOOF: iPhone 4GS/Sennheiser MM450.
Another interest:
http://www.flickr.com/photos/busb/
Rick1979
Rick1979's picture
I just bought a v dac ii, it just beats my old rotel cd player, sky hd and Xbox fed via hdmi through the tv. Hardly worth £150 is it? Very very unhappy. If you think, like i did, a dac will make a big difference you're in for a big letdown.
jimm
jimm's picture
The source, be it a Dac or Cd player will only be as good as the gear your partnering it with. I found the v-dac 2 to be excellent in my system, you will have to spend close to £500 to better it, you should look at buying a better amp or pair of speakers to get the best from the fantastic Musical fidelity v-dac 2.
__________________
paradiziac
paradiziac's picture
If you are playing CDs, a CD player is designed to do just that! I've heard the CD6004 and it's very good for the money.
DACs are more flexible and that's what I use, but depending on the transport, the cable and most importantly the DAC, YMMV. A lot of these budget DACs have cheap "wall wart" power supplies and this affects the sound quality.
On the Rega side, people say that the Rega DAC is a lot better than the Apollo, so it really is hard to generalize. Consider both options and pick the best sound for the money! You are going to demo, aren't you? Smile
Rick1979
Rick1979's picture
Thanks jimm!
However, I'm running a nad 370 and monitor audio rs6 and it ain't improved my system. Could there be something I'm doing wrong????
Aries_Zhang
It seems music streamers are more flexible and also include the future of DAC. Marantz NA7004, Pioneer N-50, Cambridge ones a in the range. More hesitate now banging head against wall
__________________
shafesk
shafesk's picture
I think you are going about this the right way. A transport (cd player) makes little to no difference when connected to a dac, as long as it reads cds well that is good enough. You get most of the sound quality from the dac. Looking at your setup, I'd suggest the Rega Dac if you want things smoother, the M1 dac is very neutral from what I've read, so your system along with your Creek could make things a little dry.
If you want to play music through your iphone you can get an airport express or apple tv for very little money and use the optical output to connect it to the dac!
Hope this helps,
Shafin
__________________
Hi-fi:
Denon DNP-720AE network streamer, Mordaunt Short Mezzo 6, Cayin A-55 T, Technics-SLQ210, Denon DP-29F turntable, 540p, Dac-magic, Marantz 5004CD and 6025 Turntable, Mac ,Pure AV interconnects, QED Revelation speaker cables, QED Performance interconnects.
Head-fi:
Akg K702, Grado SR60i, UE Triple-fi, Musical Fidelity X-cans, HRT Music Streamer 2+
shafesk
shafesk's picture
A streamer doesn't negate the need for a dac, you can always upgrade the sound quality of a streamer with a dac.
__________________
Hi-fi:
Head-fi:
Aries_Zhang
Thank you, the airport express and apple tv looks interesting.
__________________
Aries_Zhang
The streamer has dac inside. So you mean the D/A chip in the standalone DAC is better than the streamer, rigth?
__________________
shafesk
shafesk's picture
Its not just the D/A chip that counts, there are plenty other factors such as power supply design, analogue circuitry implementation among others. I have a Cowon mp3 player which has the same chip as my dacmagic but the dacmagic sounds a lot better.
To keep things simpe, 400 dac should sound better than a 400 pound streamer simply because the same amount of money is spent for a single purpose.
__________________
Hi-fi:
Head-fi:
jockey.wilson
jockey.wilson's picture
Shafin
Absolutely untrue.  Why would manufacturers invest in new transport and error correction mechanisms?
I have fed a Cyrus CD XT SE and cheap DVD player into my Naim NDX via the digital inputs, and the differences when playing music are very stark and clear to hear...
__________________
Naim NDX / 202 / 200 / NAPSC Dynaudio Contour 1.3Mkii
