Bitten by the hifi bug and want to upgrade already!!!
As some people already know I have bought my first hifi a just weeks ago but I want to upgrade it already.
Since getting a new hifi I have stopped watching TV and my PS3 is gathering dust because I spend all of the time listening to Spotify. The Yamaha speakers and DacMagic make music sound better than expected and is the best hifi I have heard for under £1000. But I have been bitten by the hifi bug and want somthing even better.
When my dad heard the Yamaha speakers he likes them so much he wants to buy some for his own computer. But now I have done a deal with him so that he will buy mine off me for a good second hand price and I will save up my wages and christmas money to buy some new speakers for £2000. It will take about 4 months to save up enough money so there is lots to time to decide what is best.
I have a small bedroom so no floorstanding or big speakers. I mostly like the sound of small speakers for the music and a subwoofer for base. I live near London so listening to speakers is not a problem. The best that I have heard so far is the Adam S1X speakers with the Adam Sub 10 although I might get away with the smaller Sub 8 because my room is very small.
Is there any speakers and amplifiers that you think I should listen to. They must go very loud and have good bass for when I watch films.
For amps maybe look at Musical Fidelity M3i, Leema Pulse or Harman Kardon HK990; and for speakers Kef R300 or Dynaudio Focus 160 / Contour S1.4 (would probably need the HK to power them)
What is the budget for the amp?
The OP uses active speakers and mentioned Adam (active) speakers as a possible upgrade. He also wants them on desk either side of a TV in a bedroom.
I don't think we are talking about amps/seperates here.
£2000 max budget for the whole system. Amplifier speakers and a subwoofer.
Thanks for the suggestion. I will look at those speakers and amplifiers at the weekend. I have listened to the Kef speakers and they are good but not as good as the Yamaha speakers to my ears.
You don't perhaps need the sub, maybe a nice extra, but not compulsory.
My choices would be AE22
ADM9RS
I do not care if it is active or seperates so long as the sound is best.
I think the AVI ADM9Ts (plus AVI's dedicated sub) still comes to around £2000 total (ish).
They should be loud enough.
The speakers will be on a desk each side of a TV
You will need to isolate the speakers from the desk using something like Auralex Mopads. It's also possible a sealed speaker like the Spendor SA1s would work better, but would have less bass.
IMO Spending £2k on some speakers to put on a desk, would considerably compromise them, so tread carefully.
ADM9RS
I have heard the AE22 which I do not like. They sound too sharp to my ears and they have been hit with the fugly stick.
I like the ADM9 speakers when I listened to them but think that the Adam speakers have a better tweeter. The ADM9 are better in the middle range than the Adam but I still like the Adam more.
Despite all I've said, I think the above is probably the best all round solution......though my suggestions are still valid (but I wouldn't put the Contours on a desk).
At the moment I am using books for desk stands but I will make some proper desk stands later.
I like the look of these stands http://www.head-fi.org/t/353449/external-dac-to-yamaha-hs50m
I have listened to the ADM9 speakers and like them a lot. They are a close second place but think that the Adam has a nicer tweeter and look better.
Have you heard the R series, which are different to anything Kef have produced in an affordable speaker?
The HK is available here and has 150W into 8 Ohms, 300W into 4 Ohms, room EQ and a DAC: http://www.thehomecinemacentre.co.uk/index.php/hi_fi/hi-fi_amplifier/har...
The R300 are £999 and the LS50s at £800 might also be a good choice.
Listen to all, before making a choice.
Cno
I have not heard the Kef R series speakers so I will listen to them at the weekend.
The Kef speakers that I have heard are the Q300 which are not as good as the Yamaha speakers. They are ok but seem a bit hard and blurry compared to the Yamaha which just sound clear. With the Kef it feels like listening to the speakers but with the Yamaha it feels like listening to just the music.
Maybe I am saying it badly because the Q300 speakers are good just not quite as good as the Yamaha speakers.
IMO The Q Series are good, but the R series are outstanding. Do also listen to the LS50s, as they are very accurate, and might suit your situation.
Let us know how you get on.
Cno
- Login to post comments
The speakers will be on a desk each side of a TV and I want to keep the Dac Magic to use as the hifi source.
Mac Mini
Cambridge Audio DacMagic Plus
Adam ARTist 6 speakers
Adam ARTist subwoofer
