BI-WIRE SPEEKER CABLE FOR HI-END SYSTEM
46 replies [Last post]
DJ_ROLANDO
DJ_ROLANDO's picture
COULD YOU PLEASE RECOMMEND A SUITABLE BI-WIRE SPEEKER CABLE FOR HIGH END SYSTEM? IS QED SILVER ANNAVERSAY CABLE SUITABLE FOR HIGH END SYSTEM?
Andrew Everard
Andrew Everard's picture
Re: BI-WIRE SPEEKER CABLE FOR HI-END SYSTEM
 ummm what's the system?
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
silly
silly's picture
Bush midi system...yes QED will be fine.
DJ_ROLANDO
My Hi End system is as follows:
PRIMARE CD31, PRIMARE PRE30 AMP AND PRIMARE A31.2 POWER AMP.
The loud speekers are DALI MENTOR 2.
Cheers.
hifikrazy
hifikrazy's picture
If I remember correctly, Andy Clough uses these cables on his Primare amplification and B&W 805 setup, so they can't be that bad.
Andrew Everard
user="DJ_ROLANDO" wrote:
Cheers.
Yes, the QED will be more than adequate for that system.
__________________
Thaiman
Thaiman's picture
QED!......I'll say nothing!
__________________
TW Raven AC - Soundsmith SG-410 - MSB 202 - Gershman Acoustics Black Swan - Audioquest K9
Andrew Everard
Hey, I only said it'd be adequate for that system. If it were me, and I had to have the Primare system, I'd be thinking Chord Odyssey or Epic.
__________________
DJ_ROLANDO
HI,
I was thinking about using Chord Epic bi-wire for my system, as the reviews in WHFSAV Magazine gave it 5 stars. Do you think there will be a major improvement on sound and overall quality of the music compared to Qed Silver annaversary Bi-wire?
Andrew Everard
Yes, definitely.
__________________
mr_wazoo
mr_wazoo's picture
Rolando what sort of music do you play?
Thaiman
Thaiman's picture
user="Andrew Everard" wrote:
Yes, definitely.
Me too Smile
__________________
Will Harris
Will Harris's picture
Darn, I have QED Silver Anniversary XT bi-wire, bi-amping my front 3 speakers, should I upgrade it for the front pair? Is it letting the side down?
__________________
JVC DLA-HD1 -- OPPO BDP83 -- ARCAM AVR600 -- DALI Helicon 800 Mk1 -- BK Monoliths FF and DF
Andrew Everard
Not unless you have a listen and are convinced they sound better, no.
__________________
Will Harris
Thanks. Am going to be auditioning the Cyrus Discmaster 8.0qx and probably an Arcam 137 shortly. Need to make sure I'm doing what I need to do to give them the best chance.
Appreciate the advice. Thanks Andrew.
__________________
DJ_ROLANDO
Hi, I am enjoy all music, mainly Hip-Hop and RNB. Also a big fan of Dance Music.
